Old 11-06-07, 10:59 AM   #1
hovis
Thumbs up get your carbs balanced
just got mine done, the mechanic said they were alot out
so off i go & see a gang of school kids ............ so i thought i would impress them with a little wheelie, i nearly fliped it its much more responsive now
Old 11-06-07, 11:01 AM   #2
Baph
Default Re: get your carbs balanced
Same applies for throttle body sync's too. Runs a lot smoother and delivers more power quicker when they're in sync as opposed to fighting each other.
I hate mine even when it's only slightly out. Sounds like a bag of spanners. Sounds lovely when it's all in sync though.
Old 11-06-07, 02:41 PM   #3
Blue_SV650S
So presuming you 'whacked' the throttle wide open to do the wheelie and assuming the butterflies weren't like 90 degrees out before balancing ... i.e. when balanced, it is generally done at idle and we are only talking differences of perhaps 10ths of a degree between 'way out' and spot on ...
Anyway for a wheelie, I presume you whack the throttle open (to 90 degrees) ... that 10th of a degree to balance is now pretty meaningless ... with this in mind how would 'balanced' carbs make any discernable difference to the power at all?
Or is this another placebo like the R6 throttle tube debate??
Old 11-06-07, 03:02 PM   #4
hovis
stuff
nah........ i like to flick the clutch
Old 11-06-07, 03:05 PM   #5
Blue_SV650S
What with the throttle fully closed?!?! ... I am surprised the front raised at all!
Old 11-06-07, 03:07 PM   #6
plowsie
Not the R6 throttle tube thing again pleeeassse
Hovis i can get mine up pretty easily(steady now U-rated site) and mines restricted, and im a fat brstard lol, i just have it at bout 2k rpm and slam it open.
Old 11-06-07, 03:08 PM   #7
hovis
its a yellow one
Old 11-06-07, 03:19 PM   #8
Blue_SV650S
its a yellow one
I suppose my yella one is my fastest one!!
I am sure it idles really smoothly, but as you can tell from my tone, I really REALLY can’t see how fractions of a degree gives a power increase/discernable differences at throttle openings …
BTW I have never balanced any of my SVs (I have the kit, but don't see the point) … but I've balanced IL4s and it is a right faff … 1/8th turn on the adjusters makes a massive difference to the readings … I don’t know how much an eighth of a turn actually relates in degrees at the butterfly, but like I said, if it’s more than 1/10th I’d be mighty surprised*!!
*you certainly can’t ‘see’ any big difference
Old 11-06-07, 03:22 PM   #9
Baph
On the pointy, you don't even need 1/8th of a turn on the adjusters for throttle bodies!! The last couple of times I've done mine, all I had to do was practically breathe on the adjuster screw!
I also balance at idle, then check & adjust where needed at around 8k RPM. Get them balanced at higher revs for an even more smooth ride. SoulKiss, if you read this, we'll be doing this to your bike too!
Blue, you're probably right, it probably doesn't add anything to power (or rather, it does, but it's such a small amount you'd need a very accurate Dyno to tell). It's more about a smoother power delivery, rather than spitting out more fire, IMO.
Old 12-06-07, 11:55 AM   #10
There's no placebo issue here, you can feel the difference between a badly balanced SV and one that works- I used to balance mine by feel, obviously not very precise but you can feel and hear the difference the adjustment makes immediately, and it's obvious enoguh to get within spitting distance of balance, at idle or at 5000rpm. Give the adjuster a spin and you'll see what i mean, you can even see the revs rise and fall as you do it. It's nothing to do with throttle openings etc, it's got more in common with jetting IMO.
Audio teccy question - balanced lines tigersaw Idle Banter 3 24-02-09 07:01 PM
Crash.NET - Rivals ahead but Rossi 'balanced'. NewsBot News 0 25-01-08 01:00 PM
Set of carbs POGS69 For Sale - SV's and SV related items 2 11-06-07 05:03 PM
Set of carbs. Nekkid Stuff Wanted 0 15-04-07 12:24 PM
balanced the carbs..... ash SV Talk, Tuning & Tweaking 1 21-08-06 04:38 PM
