Old 15-06-07, 06:10 AM   #1
steveg
steveg's Avatar
Question swap rear tyre or both after puncture
I started another thread about RAC plugging rear tyre .
Question is , going to get a new Diablo Strada Rear fitted , the front has 2.5 mm in the middle and 2 mm on the shoulder / edges , do you recon I need to change the front at the same time .
If I remember rightly you only get 3 - 3.5 mm on a new front tyre ?
What do you recon ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 15-06-07, 08:20 AM   #2
weazelz
Default Re: swap rear tyre or both after puncture
What do you recon ?
Cheers Steve
no. change it when it's needs changing. there's no need to change the front just because you're changing the rear. fronts & rears wear at different rates, so it's no uncommon for a front to last for the llife of two rears
Old 15-06-07, 08:31 AM   #3
SoulKiss
SoulKiss's Avatar
One caveat. What tyre do you have on the front. If you are swapping like for like on the back then you should be fine, but if making any kind fo change, ie mixing manufacturers or profiles, I would say may need to do both.
So what you already got on there?
David
Old 15-06-07, 09:11 AM   #4
Baph
As I said in PM, whatever you decide, ride appropriately and you'll be fine.
If you want to talk tyres, talk to Blue_SV650S. He puts all sorts on his bike, and mixes tyres. It's all about how you ride, knowing your boots aren't what they normally would be.
Old 15-06-07, 09:42 AM   #5
petevtwin650
I can recommend a good place near Stratford on Avon for tyres.
Very reasonable and he does ride in ride out.
puncture repair / new tyre Romford ukgooner Bikes - Talk & Issues 14 20-11-11 08:28 AM
Rear Tyre Puncture...dang Draper Bikes - Talk & Issues 10 13-06-08 12:29 PM
puncture repair pilot road tyre gloran Tyres 4 10-07-07 11:38 AM
M60 and my rear puncture.... ash Pennine Massive 0 10-05-06 09:06 PM
Puncture / Nail in Tyre ? SpankyHam Tyres 1 09-05-05 08:19 PM
