Old 15-06-07, 03:34 PM   #1
danf1234
Default Gilles Rear Sets Fitting
I am about to fit some Gilles Rear Sets to my bike. Question is do I need to do any bleeding of the back brake?
Is it a difficult job. Anything I need to look out for.
Old 15-06-07, 03:44 PM   #2
Flamin_Squirrel
Default Re: Gilles Rear Sets Fitting
No brake bleeding. It's easy.
Old 15-06-07, 03:51 PM   #3
danf1234
was wondering because the instructions mention bleeding the bike brake.?
Old 15-06-07, 04:11 PM   #4
rigor
I think it's because the instructions want you to fiddle with the banjo bolt on the rear brake m/c. I didn't bother, it was fine.
Old 16-06-07, 01:23 PM   #5
lawson17
I didn't do any bleeding either, the instructions suggest moving the hose fitting round, I already had Braided lines on so the angle of the fitting was different anyway. I'm unsure if it is necessary with OE hoses.
The only mod I had to do, was turn the Brake Light mounting bracket round, and use a different plastic nut on the brake light switch cos i couldn't get enough adjustment.
Old 18-06-07, 12:57 PM   #6
danf1234
Do you need the large heavy duty spring that is attached to the rear brake pedal. (Not the smaller light switch spring the other thicker one). The instructions seem to suggest it is not needed. I thought that would be important??
Old 18-06-07, 02:03 PM   #7
andyaikido
You may need to swivel the banjo bolt at the rear master cylinder as per the instructions. I couldn't get mine to fit otherwise.
If you don't want to bleed the rear brake loosen the banjo just enough to move it round to the right position then tighten again. You might get a few drops of fluid come out so have a rag/tissue handy but it shouldn't adversely affect the brake.
Anyways, who actually use the rear brake?
Old 18-06-07, 04:02 PM   #8
danf1234
What about the big thick spring that is on the OEM brake set up though. Is that not needed on the Gilles sets?
Old 18-06-07, 04:14 PM   #9
rigor
From memory, I don't think so. I think I still have the manuals kicking about at home, but I don't remember struggling to get the spring to fit, and I think the distance would be too great anyway. In fact no, because I remember fitting my spare spring to Sam's bike when her's went AWOL, so I had i left kicking around in the garage after fitting my Gilles.
Old 18-06-07, 06:01 PM   #10
andyaikido
Mine didn't use a return spring, just the spring to activate the brake light switch.
Is not having a brake return spring technically an MOT fail or something?
If you want some race bike chic you could use the rubber band method to return the pedal.
New hugger + Gilles rear sets!! Rich Bikes - Talk & Issues 25 25-01-09 06:32 PM
Giles Rear Sets Fitting nightmare danf1234 SV Talk, Tuning & Tweaking 1 02-08-07 08:03 PM
Gilles rear sets SV650 S 03-06 danf1234 For Sale - SV's and SV related items 4 24-06-07 08:54 AM
Gilles Rear Sets picture. danf1234 SV Talk, Tuning & Tweaking 5 26-05-07 07:27 PM
Fitting Gilles Rearsets??? K2 SV Talk, Tuning & Tweaking 10 20-02-06 08:09 PM
