Old 21-06-07, 10:03 PM   #1
muzikill
muzikill's Avatar
Default Clutch cable SV650k3 - cheapest where?
The cables stretched! getting near it's "adjustment to compensate" limit!
Cheers for any advice.
Pointy clutch cable simesb Stuff Wanted 0 11-04-09 03:16 PM
clutch cable DoubleD Stuff Wanted 1 01-05-08 11:17 PM
clutch cable end of life ? steveg SV Talk, Tuning & Tweaking 7 06-08-07 10:38 PM
clutch cable adjustment steveg SV Talk, Tuning & Tweaking 1 19-07-07 12:53 PM
Clutch cable 21QUEST For Sale - SV's and SV related items 1 03-04-06 12:03 AM
