Old 22-06-07, 10:59 AM   #1
Gnome
Default Front brake setup...
Not sure if it's of any use to anyone - probably only those who have fitted USD front ends.
Front brake setup from my project Bandit and what was intended for my Slingshot.
Hayabusa 6 pot calipers in good condiiton. Do have a pair of not very used pads as well.
Bandit 12 master cylinder and reservoir.
SRAD goodridge braided brake lines.
Looking for £100 for the lot.
Postage would be £10 via 48 courier.
Old 23-06-07, 07:28 AM   #2
jon8oy
Default Re: Front brake setup...
i presume your saying they only fit bikes with USD forks... or can they be converted to with adapter plates for a standard sv fork set up
jon
Old 23-06-07, 09:13 AM   #3
Gnome
I ran the same setup with adapter plates on my Bandit 6, although I had to use custom length lines (B6 lines, elongated 2 inches).
Old 23-06-07, 04:48 PM   #4
Yeah, you could definately fit those to an SV with adaptor plates. Not sure exactly how sensible it'd be though, unless you've upgraded the forks though. Should also fit to SRAD 600 and 750 forks if memory serves, which is a dead easy swap onto a carbed SV.
Old 23-06-07, 07:10 PM   #5
Gnome
Yup. I had them fitted to early B6 forks, with progessive springs, 15w oil, and SV650 preload adjusters. Once the correct setup was found, it was quite pukka.
They go straight on forks with 90mm bolt-to-bolt hole caliper lugs.
B12, TL1000, SRAD, GSXR750/ 1100, Hayabusa, Kwaka ZXR's, etc...
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front sag setup svrash Bikes - Talk & Issues 5 11-02-07 06:54 PM
Pointy K3> twin can setup for 650, does 1000 setup fit? aposegil Stuff Wanted 3 26-10-06 03:41 PM
Front Fork Setup Jester666 SV Talk, Tuning & Tweaking 7 14-08-06 03:12 PM
2002 K Series GSXR 600 Front Suspension setup parts for SV! Ter For Sale - SV's and SV related items 0 06-07-06 05:52 PM
