Old 23-06-07, 07:56 AM   #1
Grinch
Default Last 28 miles home from Soho at 55mph in 4th gear
Why was I doing this?, cus the bike lost power. I was chasing a Merc down the A3 last night just before Hindhead, and Helga suddenly lost power. Just like when you loose a fron cylinder in the rain, sometime power sometimes not. I nursed her to a illuminated spot near the lights at Hindhead and checked for oil leaks or anything else. Nothing, nada, anything.
So I rode her the rest of the way home at that speed and gear as it seemed the only way I had any power, or stop the bike popping and farting most of the way home.
Now I suspect that its one of 2 things, a breaking down coil, or a a failing spark plug. I hope its the spark plug as I have spares of those.
Old 23-06-07, 08:32 AM   #2
mattSV
mattSV's Avatar
Default Re: Last 28 miles home from Soho at 55mph in 4th gear
4rse
GWS Helga
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 23-06-07, 08:40 AM   #3
jamesobrady
Could be a broken down plug-cap...or bad contact between your HT lead and plug cap.
Old 23-06-07, 08:58 AM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
If it's not the plugs give me a shout as i've got a set of coils gathering dust in my garage
2011 Speed Triple 1050
Old 23-06-07, 09:00 AM   #5
Tim in Belgium
I had a loose coil connection that behaved similar to this, when the vibrations made the contact again normal service would briefly resume, then cut out again. Wip off the tank and airbox and check all the coil/spark connections, including the supply.
Old 23-06-07, 09:53 AM   #6
Baph
Try taking the plug off (they screw off apparently) & re-crimping the end of the HT lead, then put the plug connector back on, as well as all the other suggestions.
Old 23-06-07, 03:45 PM   #7
Grinch
Cheers everyone, will probably look at it next week what with the rain ****ing down the way it is.
Ah cheers I will.
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Home - Work - Home ukrobuk Idle Banter 9 11-04-08 09:19 AM
Crash.NET - Pedrosa: Home pole, home win? NewsBot News 0 03-11-07 07:30 PM
