Old 06-07-07, 11:57 AM   #1
ejohnh
Default Changing fork Springs and Butter bolts
So I used a 14 mm socket to unscrew the front brake caliper bolts. The top bolt was seized in tight and the socket took the corners off and the bolt is still tight in. Do impact sockets come with hex flats? Apart from drilling the bolt out, which I don't want to do, using a socket with 6 flats as opposed to a corner gripping socket seems the only option open to me.
Any?
Just gonna whip into Halfrauds to see what they got.
John
Old 06-07-07, 11:58 AM   #2
Grinch
Default Re: Changing fork Springs and Butter bolts
I would allways uses a size flat socket if I was you for those parts, and a torque wrench might be a idea so it don't get overy tightend again.
Old 06-07-07, 12:11 PM   #3
ejohnh
I will Dan. Trouble is I think the guy who had this bike before was a bit too enthusiastic with the tightening.
Old 06-07-07, 02:06 PM   #4
ejohnh
Update: Just got a couple of surface gripping sockets from Halfords
. AT first I had the normal depth ones out of the cabinet, marked as 'surface gripping' but guess what? Yep 18 pointers. So I had to get the deep sockets. Got 13 and 14 mm since these seem to be the most used. Just got home and got the bolt out no problema! It was locked tight with cement though
Anyway thanks Grinchy old bean. Can get on with this 15 minute fork out now.
Old 06-07-07, 02:15 PM   #5
jambo
jambo's Avatar
12mm & 14mm? 13mm is 1/2 an inch an not used on any Japanese bolt I've seen yet...
Old 06-07-07, 02:25 PM   #6
ejohnh
12.4mm = 1/2 ". Most of the bolts on my ford are 13mm.
Just checked and FYI The bolts which hold the pillon peg carriers are 13mm
Old 06-07-07, 06:02 PM   #7
embee
embee's Avatar
"General purpose" M8 fasteners are 13mm. A lot of automotive applications use 12mm since it's added lightness and costs less.
Similarly auto applications won't usually use the bog-standard 17mm on M10, they'll be 14mm.
....and use hex sockets (preferably face-drive types) wherever possible........
Old 06-07-07, 06:34 PM   #8
21QUEST
21QUEST's Avatar
From memory I'm pretty sure they are 12mm and not 13mm.
Perhaps not using the correct tool is what's causing the bolts to round off .
sorry couldn't resist meself
Ben
Nemo me impune lacessit.
Old 06-07-07, 10:21 PM   #9
ejohnh
Ben
Accept it, you have a crap memory Ben.
John
Fork springs Bill.Cross SV Talk, Tuning & Tweaking 11 29-01-09 07:49 AM
Changing my fork springs ejohnh SV Talk, Tuning & Tweaking 15 04-07-07 01:41 PM
Fork Springs for K3 M65 Stuff Wanted 6 08-05-06 03:49 PM
Fork springs? Jase22 Stuff Wanted 4 23-11-05 09:00 PM
Fork Springs? bobit69 SV Talk, Tuning & Tweaking 3 21-01-05 10:34 AM
