Old 08-07-07, 08:00 PM   #1
tomjones2
Default valve clearances - general
I have been checking the valve clearances and come into some problems with the instructions.
To cut a longish story short is measuring the valve clearance at any point on the "round" part of the cam acceptable?
Old 08-07-07, 09:28 PM   #2
Flamin_Squirrel
Default Re: valve clearances - general
Have you rotated the engine to the correct position?
If you have, the cam will be pointing upwards so when you get the feeler gauge between the cam and the shim it'll be on the round part of the cam where it should be.
Old 08-07-07, 09:50 PM   #3
tomjones2
This is the problem, the instruction got me a little confused. When the engine is rotated to the correct postion according to the intructions the cam is touching the shim with the lobe bit, therefore cant get the gauge in.
So I have measured them with the cam pointing upwards instead. I have assumed that as the shim is spring loaded and the cam has the round bit the gap will always be the same providing you are not measuring it with the lobe bit, is this correct?
Old 08-07-07, 10:12 PM   #4
toonyank
Ideally you should measure in the "correct position" however in reality as long as you measure on any part of the "round" part before the tangent of where the lobe starts you will be fine because this is a diameter where the gap should be.
Old 08-07-07, 10:24 PM   #5
TSM
The Sick Man
TSM's Avatar
Remember that you have rotate the engine 360 before you check each cylinder, they dont both align up on 'F' at the same time. As peeps say, just rotate the engine till the pointy part of the lobe is facing away from the shim bucket.
Old 09-07-07, 06:09 AM   #6
Flamin_Squirrel
Of course, F being the correct position for the front cylinder, R being for the rear.
Valve clearances. Grinch SV Talk, Tuning & Tweaking 89 29-08-11 09:20 PM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Valve clearances yorkie_chris SV Talk, Tuning & Tweaking 41 28-09-07 06:46 AM
Adjusting valve clearances - general (Z750) tomjones2 Bikes - Talk & Issues 4 11-07-07 10:54 AM
Valve Clearances HELP TSM SV Talk, Tuning & Tweaking 25 05-04-06 09:58 AM
