Old 12-07-07, 07:04 PM   #1
Paws
Default Very little front brake
Argh, thought we had sorted this on my sv but its come back!
Have very little front brake on my curvy, was like it when i got her, spent ages in garage getting them to sort it-got her home, all sorted-that was Sept last year.
Last couple of days its faded again! help!
Its been bled, had new pads, new seals etc.
I can almost get it back to the bar before bike fully stops, , garage last year suggested getting rid of braided lines and putting standard back on.
Old 12-07-07, 07:24 PM   #2
BILLY
Default Re: Very little front brake
I know you have blead them but it sounds like you still have some air in the system! Try cable tying the lever back over night and see if that cures it.
BILLY
Old 12-07-07, 07:37 PM   #3
Paws
ive done that before, it helps but it soon comes back
im going to try and find a new master cylinder and see if that has any effect.
Old 12-07-07, 07:46 PM   #4
Grinch
Master cylider servicing kit about £18 or something like that... fixed mine. Use a cable-tie to keep the leaver closed over night and if the brakes are sharp when you first use them and fade over the day then its likely to be that.
Old 12-07-07, 07:47 PM   #5
chazzyb
Sounds like you *may* have the retracting piston syndrome I seem to have. Despite new seals in calipers and master cylinder + new braided lines, I still have more lever travel than I'd like before the brakes bite. They then work very well indeed. It's just one of my calipers that seems to be the problem. When I bought the bike (4 years ago now), I had the lever adjuster set to 4 for my small hands. I've now got it on 1 so the lever doesn't come back too far when braking grabbing a handfull.
I don't know the answer either...
Old 12-07-07, 07:48 PM   #6
Paws
Alreday did that the first time round huni, worked a treat up until now
Old 12-07-07, 08:03 PM   #7
Torn-Thorax
Maybe the suz peeps are right and there is something dodgy with your cables.
Old 12-07-07, 10:19 PM   #8
Grinch
How many miles has the bike done now? And is it parked outside?
Old 12-07-07, 10:25 PM   #9
Paws
ermm had done 27k when i got her/ first had problem sorted, its now on about 31k and isnt stored outside.
Old 13-07-07, 09:02 AM   #10
Grinch
Very odd... Have you tried keeping the leaver closed overnight?
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
