Old 17-07-07, 09:18 PM   #1
Lozzo
Default R6 Throttle tube mod done
And it works.
Travel is drastically reduced from 1/4 turn to less than 1/5 turn, from closed to fully open.
I used Yamaha part number 5SL-26240-01-00 on a '03 model naked pointy. Modifications to the R6 throttle tube to ensure it was fully opening and closing in the SV housing were made as per the pictures found here :
http://forums.sv650.org/showthread.php?t=83740&page=2
Cost was about 8 quid and the tube came with the throttle grip rubber, so well worth it.
Nice
Old 17-07-07, 09:22 PM   #2
BILLY
Default Re: R6 Throttle tube mod done
I bet it has added 30bhp as well
But seriously well worth it
Old 17-07-07, 09:27 PM   #3
Lozzo
I'd be happy with just 25bhp extra, I'm not greedy. It's a nice cheap mod and should help me as I suffer with a touch of RSI.
Old 17-07-07, 10:41 PM   #4
jonboy99
And it works.
Nice
How long did it take? Is the throttle grip the same diameter as the original one on the left bar?
Old 17-07-07, 10:59 PM   #5
Lozzo
I'm a mechanic by trade, so it took me a total of about half an hour to modify and fit it, then adjust the cables and check it.
If there is a size difference then I didn't notice, but I happen to have a Yamaha left grip of the same pattern on my bike anyway (acquired when I fitted heated grips to a new FJR1300) Even if there's a 2mm difference in diameter, you won't notice. It's not like one will be 10mm thicker or something...grips is grips, they're all about the same diameter give or take a mm or 2.
Old 17-07-07, 11:54 PM   #6
ASM-Forever
And it works.
Nice
Good start.....just the rest of an R6 to transplant over
Old 17-07-07, 11:55 PM   #7
Lozzo
The throttle tube is the only good bit I've found on any R6.
Old 06-02-13, 03:28 PM   #8
Redmist
Did you modify the housing around the end of the throttle tube to give more room for the larger diameter??
I've seen it somewhere that it is necessary but I don't know an easy way to remove material from the housing?!?
Mine came with the housing from the R6 but the entry point of the cables is further from the bars
R6 Throttle Tube plowsie SV Talk, Tuning & Tweaking 0 19-06-07 10:21 AM
R6 throttle tube svryanpompy SV Talk, Tuning & Tweaking 8 08-03-07 09:17 PM
R6 Throttle Tube jonboy SV Talk, Tuning & Tweaking 128 06-01-07 06:41 PM
throttle tube 01 sv650s SV Talk, Tuning & Tweaking 1 21-11-06 02:25 PM
R6 throttle tube for a K4 SVeeedy Gonzales SV Talk, Tuning & Tweaking 0 04-01-06 12:22 PM
