Old 19-07-07, 09:33 PM   #1
Gloggers
Default Headlight pointing wrong way
Hey all,
I had my Sv imported from Germany and saved myself a few quid, but the only problem is that the headlight points up to the right, is there any way I can rectify this?
I have tried adjusting the headlights with the screws either side, but it doesn't bring down the right without bringing the left way down and completly useless.
Any ideas?
Old 19-07-07, 09:53 PM   #2
rictus01
rictus01's Avatar
Default Re: Headlight pointing wrong way
Yeah, buy a uk spec unit.
you can get stick on bits to stop you blinding other road users, but these won't pass an MOT,so you'll only get away with it for the first 3 yrs ( the police could stop you at any point though, so be warned).
Cheers Mark.
(Edit:-Oh just seen you're in Ireland, not sure what the rules are over there ????)
Old 19-07-07, 09:56 PM   #3
Tim in Belgium
I had to change my headlight unit when I came back to the UK, try some breakers and ebay for spares, but they can be pricey as they're often broken/scratched in crashes.
Old 19-07-07, 10:18 PM   #4
Gloggers
Cheers Mark.
No MOT over here, so dont need to worry bout the legal side of things, just blinding other road users and being able to see the ditch!
So is it the reflective mirrors I would have to change or the whole front unit?
Old 20-07-07, 07:04 AM   #5
John Burt
Whole headlight unit I'm afraid, start trawling the breakers, or maybe one of the track boys on here might have one??
Old 20-07-07, 01:05 PM   #6
BILLY
Can't you fit a Fox eye thats what some import bike have on them to make them legal!
Old 20-07-07, 01:09 PM   #7
Stu
Trinity
Stu's Avatar
you can get stick on bits to stop you blinding other road users, but these won't pass an MOT,??)
When I MOT'd my Cougar, that's what the MOT place did for me without asking me & passed it. Guess I was just lucky.
The high bit to the left that you're missing won't help you see the ditch, only road signs. So definetly cheaper to play about with black tape to mask the correct bit.
Old 20-07-07, 11:02 PM   #8
Gloggers
Oh right thanks for the replies guys! Appreciate it. Will check out the fox eye idea, then the black tape, then the whole unit.
Thanks
Old 23-07-07, 08:36 PM   #9
hoodlum
you will also need to check the wiring loom - the UK spec bikes have twin headlamps that illuminate, the euro bikes have single beam lamps and an unhelpfully different wiring loom.
Old 23-07-07, 09:22 PM   #10
Gloggers
Sorry, dont get you? Do you mean on the euro models one is for dips and the other for high beam?
If so, both of my headlamps light up when on dips and high beam.
Is it wrong what I did? touch107fm Bikes - Talk & Issues 103 06-03-09 10:14 PM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
When wearing high heels was wrong, so wrong... Razor Idle Banter 6 03-06-06 08:51 AM
Headlight Mounting bracket, headlight vincerhodes Stuff Wanted 1 10-05-06 07:12 PM
Wrong Construction wrong colour . amarko5 Bodywork 12 30-10-04 03:23 PM
