Old 25-07-07, 08:50 PM   #1
muzikill
muzikill's Avatar
Default Rear sprocket + Top of fork cleaning?
Sprocket on rear wheels a bit 'weathered' looking any ideas on what can get it shiny again?
Plus the top of the forks near the yoke have some rusty spots showing, what can be done to clear these up and protect it?
Cheers for any advice.
Old 25-07-07, 08:56 PM   #2
leesvee
Default Re: Rear sprocket + Top of fork cleaning?
Get the rear wheel off and pull the sprocket carrier out then wd40 and an old tooth brush and a rag to mop up will clean it up nice maybe aided by a wire brush.
Forks - autosol and a bit of elbow grease ( or a dremmel type tool with a polishing mop)
Old 25-07-07, 09:04 PM   #3
Old 25-07-07, 09:05 PM   #4
Autosol, Autosol and more Autosol oh and no life
Old 25-07-07, 09:08 PM   #5
muzikill
muzikill's Avatar
Autosol for the exhaust too? for tidying up the pipes at the engine?
Nice shiny chain btw! - hmmm wonder if i can use that too!
Seen a dremmel set for sale in b n q nice and cheap - ticked to buy on pay day!
Old 25-07-07, 09:09 PM   #6
got my dremmel tool thingy from makro @ £14.99 + vat.
Old 25-07-07, 09:10 PM   #7
Autosol for everything except tyres and brakes.
Old 25-07-07, 09:38 PM   #8
BILLY
Don't worry about cleaning just ride it
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
cleaning the chain/sprocket! Jimmy2Feet SV Talk, Tuning & Tweaking 11 27-10-06 08:47 PM
Cleaning inside the sprocket cover andyaikido SV Talk, Tuning & Tweaking 19 09-08-06 11:05 AM
Rear Wheel Cleaning DanDare SV Talk, Tuning & Tweaking 23 02-08-06 09:51 AM
cleaning rear sprockets Warren Bikes - Talk & Issues 24 12-10-04 03:59 PM
