Old 26-07-07, 04:55 PM   #1
Default Immobiliser fault
Hey, my curvy has a meta system alarm immobiliser on it, just now stopped off for 10 minutes, came outside and it wouldn't mobilise.
Tried to bump it, but the system earths the ignition too so that didn't work, pushed it to the top of the big f#cking hill, tried to start it normally again, and it started
I think its a meta M357T or something like, does anyone know where these are connected into the loom as i presume its a shorted wire, unless anyone has any other ideas?
Any help would be greatly appreciated!
Chris
Old 27-07-07, 11:36 AM   #2
Default Re: Immobiliser fault
Had a look today and can't find any obviously broken wires.
Also my full beams don't work but thats a fault at the front (the repeater light still works)
I sodding hate wiring!
Old 27-07-07, 01:40 PM   #3
melody
I think I can help
Either
The cylinder head gasket is damaged because you've allowed it to become loose or there is excessive carbon build up on the piston crown and combustion chamber causing extremely high compression so the head gasket leaks. Retorquing the head is not sufficient to restore the seal, so you'll definitely need to replace the gasket.
Or
The carburettor intake manifold is loose. You need to check for cracks, breaks, tears or loose clamps. renew the rubber intake manifolds if they are split or perished.
Failing that
There is carbon build up in the combustion chamber. Use of a fuel additive to dissolve the adhesive bonding the carbon particles to the piston crown and chamber is the easiest way to remove the build up. Otherwise, the cylinder heads will have to be removed and decarbonised
If your'e still struggling, bring it over and I'll sort it for you.
Melody
Old 27-07-07, 01:42 PM   #4
melody
Sorry Chris. Couldn't help myself. I look like I know something now, even if its not helpful to you at all
Hope you get it sorted
Old 27-07-07, 02:14 PM   #5
BILLY
I see youv'e been reading a haynes manual melody
It could be a fault with your imobiliser is it still under waranty? If it is take it back to where you got it fitted! Or remove it and throw it away!
BILLY
Old 27-07-07, 06:19 PM   #6
Probably not, previous owner fitted it.
It's working absolutely fine now.
Have located the wires to the ignition kill so I know where to cut if it does it again! (this will let me bump start it)
Have also stripped the loom, attacked it with WD40 and compressed air and sprayed it all with PTFE spray, should keep it dry.
Chris
Edit: Remembered yesterday there was a lot of fairly deep water running down the roads near me, got rather wet, this water coming up could have caused it?
Old 27-07-07, 06:46 PM   #7
I had that immobiliser's predecessor, the M1. Finally binned it last year, I hate the things, it's not like hotwiring bikes and riding them away is common. Hardly difficult to remove, either, took me about half an hour taking great care so a thief would probably remove it in 5 minutes. Though, I used to be bad for leaving my key in the seat lock so I kept the immobiliser key on a seperate keyring.
Old 27-07-07, 06:54 PM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
Has that changed then? (i still do it )
2001 SV650 in shimmerin green, Not broken anymore
Old 27-07-07, 06:59 PM   #9
Yep, I finally got slagged off so much that I stopped doing it- developed a "where's me keys" routine at last after 5 years of riding.
immobiliser/alarm stanie Bikes - Talk & Issues 12 11-09-08 05:49 PM
Alarm? Immobiliser? TazDaz SV Talk, Tuning & Tweaking 6 17-08-08 02:44 PM
Best immobiliser? blueto SV Talk, Tuning & Tweaking 8 04-02-08 07:40 AM
Removing an immobiliser? northwind SV Talk, Tuning & Tweaking 3 15-10-06 01:32 AM
Immobiliser - How much??? branny SV Talk, Tuning & Tweaking 8 29-04-05 07:07 PM
