Old 04-08-07, 08:07 PM   #1
florida650
Default sv wont start 2000 carburated
im trying to start the sv its carburated.... but all it does is cranks..it seems to have enough battery power to start cuz the headlight is pretty bright...
i have tried to increase the fuel on the choke...and have also tried to give it gas as i crank... do you thinnk i have flooded the spark plug?...
is there anything else i can try..its a beautiful saturday i would hate to drive my cage or car today
thanks... if you guys are still awake in the u.k
Old 04-08-07, 08:13 PM   #2
BILLY
Default Re: sv wont start 2000 carburated
Kill switch?
Old 04-08-07, 08:20 PM   #3
florida650
Originally Posted by BILLY View Post
Kill switch?
where is that located? ... man im such a newbie... help this cager out
Old 04-08-07, 08:26 PM   #4
husky03
husky03's Avatar
on the right hand side just above your light switch.
husky03 is offline   Reply With Quote
Old 04-08-07, 08:27 PM   #5
florida650
ROFL..Im not that ****ing much of a newb..i at least completed the MSF course..
any other suggestions?
Old 04-08-07, 08:40 PM   #6
florida650
the light switch is on the left here in the states...
i got it to work ..i guess you just gotta let it sit...
Old 04-08-07, 09:13 PM   #7
BILLY
You proberbly just flooded it then!
Old 04-08-07, 11:20 PM   #8
florida650
yeah i guess so... but.. i dont understand..when i havent started my bike in like a week.. should i put the choke on max ???... or should i leave it on 'lean'...
Old 04-08-07, 11:29 PM   #9
the_runt69
Depends mine wont start with the choke on (same model as yours) but wont run unless you let it run with a bit of choke after she's started
Old 05-08-07, 12:01 PM   #10
embee
embee's Avatar
I find most carbs of this type will start fine using choke but NO THROTTLE. If you use the throttle at all with the choke on, it'll refuse to start often as not.
If mine is "cold" I use full choke and no throttle, then back off the choke as much as possible as soon as possible, ride off gently straight away and it will run fine on no choke after only 50yds or so.
If it is warm at all, say it's run in the last 5hrs or so, then no choke is required, just a touch of throttle to keep the idle speed up.
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
sv wont start robbieracer SV Talk, Tuning & Tweaking 4 25-02-07 01:55 PM
HELP! it wont start sLaYeR SV Talk, Tuning & Tweaking 3 29-06-06 09:58 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
Boo! It wont start. bulldoggy SV Talk, Tuning & Tweaking 14 28-03-06 05:27 PM
