Old 08-08-07, 09:26 AM   #1
plowsie
Default Horrible Metal Scraping Sound
Only happens as i pull away in high revs, and only pulling away. High revvs let the clutch out and then a horrible crunching scraping metal sound as i move away, only lasts for like a second. Anyone know what it might me?
Old 08-08-07, 09:30 AM   #2
sinbad
Default Re: Horrible Metal Scraping Sound
Chain slipping? Sprockets ok?
(Guessing)
Old 08-08-07, 09:31 AM   #3
Richie
fantabulas
Richie's Avatar
How tight is your chain ?
My Flickr photos
Old 08-08-07, 09:33 AM   #4
plowsie
chain is tight, this sounds weird but it feels further forward then the chain and sprockets but then again it could be the front sprocket, sounds like it is on the left aswell, i thought maybe clutch is screwed but had a full service on it and it was doing it before and is still doing it.
Old 08-08-07, 09:38 AM   #5
stewie
Hi, no expert on these things but sounds like clutch to me, cos pulling away put max pressure on clutch, could be pressure plates ?
Old 08-08-07, 09:39 AM   #6
dirtydog
Knob faced knobster
dirtydog's Avatar
What sort of high revs are we talking about here?
2011 Speed Triple 1050
Old 08-08-07, 09:40 AM   #7
plowsie
6 or 7, will do some testing on the way home
Old 08-08-07, 09:42 AM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
How about using less revs to pull away?
Old 08-08-07, 09:44 AM   #9
plowsie
Well yeah there is that, still doesnt solve what the problem is, it just hides it.
Old 08-08-07, 09:47 AM   #10
dirtydog
Knob faced knobster
dirtydog's Avatar
but the problem only happens when you rev it hard to pull away, metal scraping noises generally aren't good so if it's not making that noise it's unlikely to be causing any damage
scraping footpegs through the corners coldtyres SV Talk, Tuning & Tweaking 31 01-11-08 04:58 PM
Peg Scraping! Need more clearance! dmracing SV Talk, Tuning & Tweaking 13 22-08-07 03:15 PM
Scraping the bottom of the barrel jonboy Idle Banter 8 05-05-06 04:05 PM
Hugger scraping the wheel? carty Bikes - Talk & Issues 1 12-04-06 01:59 PM
pads and discs scraping rob13 SV Talk, Tuning & Tweaking 9 09-02-06 06:42 PM
