Old 09-08-07, 11:07 AM   #1
aarond
Default Forks
Sorry if this has already been done i have searched the forum and i think now i am ready to upgrade the forks and was just wanting to make sure i was right. I have a 99 Curvy done 35K and was wanting to upgrade to ohlins springs so if i am right do i just need:
10 weight Ohlins Fork fluid
Ohlins fork springs
Dust seals ( mine are perished)
Oil seals
and to follow the instructions from
http://www.bluepoof.com/motorcycles/howto/svs_fork_oil/
I was planning to get the springs and oil from demon tweeks and the seals from a local suzuki dealer.
Is this correct? Or is there a better option.
thanks, Aaron
(Dont know if you need my wieght i am 75kg)
Old 09-08-07, 11:15 AM   #2
Default Re: Forks
Yes and no.
Yes, you'll need the springs and a litre, (not a liter), of fork oil of the chosen viscosity.
No, you don't need to replace the seals, (unless they're leaking of course).
Fitting a new dust shroud only requires the fork to be removed to slide the shroud over the end.
The forks don't need to be dismantled to fit springs - it's exactly the same as replacing the fork oil, only you put the new springs in when you've refilled the forks with oil.
Old 09-08-07, 11:19 AM   #3
petevtwin650
Default Re: Forks
Have a look at this thread before purchasing from Demon Tweeks. There are plenty of suppliers for Ohlins springs out there.
http://forums.sv650.org/showthread.p...t=demon+tweeks
JHS for one I believe.
Old 09-08-07, 12:00 PM   #4
r4ce_e3nd
Default Re: Forks
I would consider 15 weight of fork oil.
What spring rate will your springs have?
If your seals do not leak any oil you will not need to replace them...
Old 09-08-07, 12:51 PM   #5
rictus01
rictus01's Avatar
Default Re: Forks
Whilst playing with the forks you may find this of benefit, although you've got no (unless it's a K2>) adjustment outside, you can easily measure and adjust the spacers in the forks to setup static sag.
Suspension setup guide
Cheers Mark.
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
forks jon8oy SV Talk, Tuning & Tweaking 26 04-12-07 08:34 PM
R1 forks yorkie_chris SV Talk, Tuning & Tweaking 4 15-11-07 07:10 PM
Forks markmoto SV Talk, Tuning & Tweaking 7 13-07-07 12:22 PM
Forks Viney SV Talk, Tuning & Tweaking 11 14-03-05 08:52 AM
