Just wondered if you guys could offer me some advice. I've had my sv for oodles of years now, and have noticed that when I have her loaded up for shows, rallies etc. the extra weight on the bike actually makes it a better ride for me. Makes the bike feel more grounded....not so light...I was wondering if there are specialised places I can go, or just to a garage and get this sorted out...?
And more importantly, if I have it altered to suit me without a load, will it be worse or okay with load afterwards? Cheers |
Knob faced knobster
is your preload set to high on the rear shock?
2001 SV650 in shimmerin green, Not broken anymore |
Probably. I've just been reading through the other posts, and it seems everyone has the opposite problem to me. I don't have the tool kit so don't have the tool to alter it...I think I'll take the bike down to a mate's shop and get him to check it out for me.
Knob faced knobster
i had my pre load set to max a little while ago and it felt very skittish if that makes sense? handled better when i turned it back down again
Yes, I found the same thing: having a tailpack on the back (although not a pillion) made my bike feel nicer and more planted. Initally, I put this down to the knackered stock rear shock. I've since replaced this with a Nitron shock (the most basic one without a remote resevoir). This has significantly improved the handling and after a bit of tweaking of the combined compression/rebound damping dial almost completely eliminated the wallowing I was previously suffering. I haven't bothered to alter the ride height and nitron assured me that the spring/preload were shipped at their recommended setting to suit my weight.
Now, the effect is certainly less pronounced with the new shock, but with the new shock, I still find it seems a bit more planted with a tailpack on. Any ideas as to why this might be? Do I just prefer "heavier" more planted bikes (I do like cornering on bigger bikes than SVs)? Is there more tweaking of the suspension (preload) that I should do to sort it? TIA. Clanger, what rear shock have you got on your bike and what's the mileage of it? |
Tyre pressure too high?
#9 |
It was a bit skittish in the early days, so I had the fronk fork springs changed...that did the trick...and the tyre pressures are usually 32 front and 34 rear.
#10 |
I find the SV handle better two up. It seems to like wieght.
Suspension | M65 | SV Talk, Tuning & Tweaking | 28 | 14-12-19 11:47 PM |
suspension when 2 up | Draper | SV Talk, Tuning & Tweaking | 5 | 08-05-08 10:27 AM |
What suspension? | Mike2165 | SV Talk, Tuning & Tweaking | 17 | 26-09-07 01:11 PM |
Suspension | Cos | SV Talk, Tuning & Tweaking | 4 | 17-05-05 12:26 PM |
suspension set-ups . . where ? | Warren | SV Talk, Tuning & Tweaking | 9 | 06-05-05 06:11 PM |
