Old 15-08-07, 07:50 PM   #1
leemole
Exclamation front brake disc
to fit on a 99 naked. I need the left side as your sat on the bike mine has gone all wobley
cheers
Old 17-08-07, 06:52 PM   #2
NedSVS
Default Re: front brake disc
Your front brake discs can be repaired. Stealth products make replacement rivets (or bobbins as some people call them) which come with the wavey spring washers and a circlip to retain them. I have got a set of 12 (i.e. enough for both front discs - if my experience is anything to go by the other disc will go soon). You need to grind the head off the original rivets to remove them. I have changed wheels and discs so dont need them. This is the copy of the email from stealth:
THANK YOU FOR YOUR ENQUIRY.
WE CAN SUPPLY NEW BOBBINS, RIVETS & CLIPS FOR YOUR BIKE - THEY ARE £2.99 EACH
PLUS £6.95 P&P.
STEALTH PRODUCTS.
So I paid £42.83 inc P&P in total. As I no longer need these Make me a reasonable offer and they are yours.
2003 Pointy Front RH side brake disc. leegriffiths128 Stuff Wanted 6 13-11-08 01:14 PM
Brake Disc Loose. CB1ROCKET Bikes - Talk & Issues 17 15-05-08 09:27 AM
front brake disc question Ryest SV Talk, Tuning & Tweaking 5 31-10-07 09:02 PM
Very wobbley brake disc maxdan SV Talk, Tuning & Tweaking 2 10-07-07 07:20 PM
Brake Disc thickness andyb SV Talk, Tuning & Tweaking 7 14-11-06 10:49 AM
