Old 20-08-07, 06:25 PM   #1
the white rabbit
Default Wireless v vs wired, selecting as needed
In XP, how do you set your network connections so that when my laptop is connected to my router via a cable (normal) it also doesnt also use the wireless network to connect. Is there a preference setting? Or doesnt it matter?
Old 20-08-07, 06:27 PM   #2
gettin2dizzy
Default Re: Wireless v vs wired, selecting as needed
turn wireless off completely. Save some battery too.
Old 20-08-07, 06:30 PM   #3
the white rabbit
Its not quite as simple as that, I'm afraid. I also have a desktop with a wireless in it that I am sometimes using and sometimes not as I have had to move my router in and out of the room with the desktop in (long dull story).
I cant switch wireless off on the router as I have a third computer I need it for.
Old 20-08-07, 07:17 PM   #4
fizzwheel
fizzwheel's Avatar
Dr Rich, can you not turn the wireless off on the laptop when you dont need to use it, On my laptop theres a button that enables and disables the laptop.
Failing that you could go into the network section and right click the wireless connection and disable it that way.
I'm not sure if theres a thing in XP where you can set a preference order for the network devices, my work laptop is at work and Liz's laptop has Vista on it which probably doesnt work the same way...
Old 20-08-07, 08:51 PM   #5
the white rabbit
Yes but also the desktop has a wireless card. I am having router issues (ongoing) so am ahving to experiment with different setups. I think you can set a preference for the order that XP selects the network device.
Old 20-08-07, 09:01 PM   #6
Ruffy
Ruffy's Avatar
You can set up different hardware profiles that can be selected at power up, so you could have one with wired enabled/wireless disabled and one with wireless enabled/wired disabled. However, I think this means you have to reboot if you want to swap from one to the other - may or may not be a problem?
The only other thing I can think of is to configure your wireless link as a manual/on demand connection, so that it will not ever connect automatically.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 20-08-07, 09:04 PM   #7
Grinch
If I remember correctly it goes like this - Start - Control panel - network connections - select advanced menu - advanced settings - Then change the order of the connections window to your preference.
So in your case it will need to try wired first then wireless it that fails.
Might be wrong but it seems tp works on my laptop at work, but then it does have this extra software that comes with it that does some other stuff so I can't truely test it.
Old 21-08-07, 06:09 AM   #8
the white rabbit
Thats what Im looking for! Is it the 'metric' on the TCP/IP protocol?
Edit, Ah, ok, Advanced on the main menu bar. Never looked there, only on prperties for connection.
Old 21-08-07, 07:56 AM   #9
Grinch
Did this work ok?
Old 21-08-07, 09:29 AM   #10
the white rabbit
Not sure as at office now, will try this eve or tomorrow.
Setting up a wired+wireless network..... 5v5 rider Idle Banter 23 18-04-09 04:03 PM
Heated Waistcoat (Battery Pack, not wired in) vardypeeps Riding Gear 0 02-01-09 04:55 PM
External (and internal) wired IP Cameras Blue_SV650S Idle Banter 17 21-06-08 05:30 PM
Cool cannonball run article in wired thor Idle Banter 0 17-10-07 10:25 AM
Any wireless wizards out there? Belkin router help needed Well Oiled Idle Banter 12 18-03-06 12:42 PM
