Old 22-08-07, 11:00 AM   #1
riktherider
Default Clutch kits...whats the best one to get??
decidede to change my clutch after clunky gear box, and too many false neutrals. is it best to replace the plates and springs or just the plates? whats the best make to go for? ferrodo, EBC, Surflex?
Old 22-08-07, 11:13 AM   #2
Viney
Default Re: Clutch kits...whats the best one to get??
It wont be the clutch. Its more likely to be the selector mechanism.
However if you must, then the suzuki kit is good. DONT USE HEAVY DUTY SPRINGS. They are nto needed and all it does is kill ya hand.
Others, Barnet, and EBC. I have EBC plates in there, and afaik, they are fine. Its my steels that are warped!!
Old 22-08-07, 11:19 AM   #3
riktherider
i thought it could e the shift detent arm or the star, but its a bit more pricey than the clutch, plus the bike is 99 and done 45000 miles.
Old 22-08-07, 11:51 AM   #4
jambo
jambo's Avatar
Don't replace bits untill you know they're duff, if the clutch isn't slipping after being adjusted correctly then I wouldn't bother looking at the plates. If it doesn't solve the problem it's just money down the drain.
Old 22-08-07, 12:09 PM   #5
Captain Nemo
if its not slipping, then unlikely to be the plates, maybe the springs are a bit weak, if swapping them, then do the plates at the same time, but its prob the selector, like you say 45000 miles, dont throw money it at "just in case" just chucking it away.........
Old 22-08-07, 12:26 PM   #6
TSM
The Sick Man
TSM's Avatar
Yep thoes Heavy duty springs have sometimes caused me to stop riding the bike on the weekends as its made it too painful to use the clutch, but on the upside i did not suffer so much clutch slip with my heavy handed changes. But as a general rule i would not get them again, i needed new ones at the time because my standard ones had gone way below tolerance.
I went barnet just on the hype, and if you were going OEM they are about the same price.
Old 22-08-07, 01:58 PM   #7
I've got at least one spare arm and star in the garage somewhere, in one of the boxes of bits... But I'd be surprised if this is your problem either. The ones out of the K5 onwards SV are better than the earlier ones, Suzuki rather cunningly ripped off the Factory Pro shift kit And I think they cost around £60 for the parts if memory serves- I've got the Factory Pro bits and they're a nice upgrade but, like I say, I don't think it'll fix your problem.
Old 22-08-07, 02:08 PM   #8
TSM
The Sick Man
TSM's Avatar
42.54 shipped from Robinsons Foundry
25381-19F10
PLATE, GEAR SHIFT CAM
25350-35F00
STOPPER, GEAR SHIFT CAM
25355-35F01
SPRING, STOPPER ARM
Old 22-08-07, 02:12 PM   #9
svrash
Alos try taking out the push rod and give it a good clean and grease, just take the worn drive off and pull the rod out. If it's caked then it'll stop the clutch pushing out properly
Old 22-08-07, 04:20 PM   #10
RandyO
I always found false neutrals to be caused by dirty shift linkage and sloppy shifting
STEAM - Whats your user name? Whats your game? ThEGr33k Idle Banter 8 08-01-09 10:06 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Dynojet kits...........whats in them? svrash Bikes - Talk & Issues 17 13-06-06 10:14 AM
Clutch kits **Bargin** Viney SV Talk, Tuning & Tweaking 29 03-03-06 10:21 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
