Old 03-09-07, 07:15 PM   #1
monkey
Default Bike cleaners question-Cleaning to sell.
Hello. I'm clenaing my bike to sell and was just after some know how. I have wheel cleaner, brake cleaner and a solvent spray degreaser. What is safe to use where cos I always hear you can use this on that and that on this etc but can't remember which is which. Before you all butt in and say use them for what they're for I'm not that silly but I'm sure brake cleaner can be used on loads of things. Am I right here?
Also, any good tips on cleaning up a bike to sell would be appreciated. Which bits are looked at and which aren't.
Thanks.
P.S. I have some rust on the lower triple clamp. Will fine wire wool do the trick for this?
Old 03-09-07, 07:35 PM   #2
monkey
Default Re: Bike cleaners question-Cleaning to sell.
Oh yeah I've got chain cleaner too.
Old 03-09-07, 07:35 PM   #3
Alpinestarhero
Thanks.
Dont get anything on the brakes except the brake cleaner, try not to get anything on the tyres but if you do rinse it off with alot of water. Brake cleaner can also be used to clean the chain and sprockets I think (but re-lube the chain after!)
Matt
Old 03-09-07, 07:37 PM   #4
Alpinestarhero
Oh, the degreaser - only use it if you really really have to
Matt
Old 03-09-07, 07:40 PM   #5
monkey
Why's that with the degreaser?
Old 03-09-07, 07:42 PM   #6
fizzwheel
fizzwheel's Avatar
Muc off, spray it all over, agitate and then rinse off.
Use the degreaser on the manky engine bits, WD40 sprayed on a rag brings up wheels a treat. But keep it away from the brake disks...
Then get some Mr Sheene and a soft cloth and spray all your plastics with it, brings up nice and shiney.
I'm a bit picky and I tend to climb all over a bike when I'm looking at one, I'll poke about inside the fairing and give it good going over.
I tend to look at the mechnical stuff, more than cosmetics though TBH.
Old 03-09-07, 07:44 PM   #7
i only use wd40 on the engine and oily bits, autosol on the shiney bits and a good polish on the paintwork. when i go to buy a bike thats advertized as "MINT" i always look at the chain an sprocks, back wheel and swing arm, forks and front wheel, exhaust, if these parts are in good condition clean and tidy then i'm happy.
Old 03-09-07, 07:44 PM   #8
Alpinestarhero
It can be quite strong, and corrode things (rubber tubing, may affect the tyre rubber etc)
As long as you wash it off, its ok, but I'd rather avoid using it all together and put in some elbow grease
but if you gotta use it, use it. Just be carefull
Matt
Old 03-09-07, 08:42 PM   #9
monkey
Cheers. Is Muc off that good? I've always used turtle wax car cleaner!
I haven't really got any manky engine bits as it's only 7500 miles old.
Had the rear wheel off to get a puncture repaired so used the opportunity to give it and the sprocket a good clean-in the bath! (Live in a top floor flat). Gonna do swing arm and shock tomorrow.
Old 03-09-07, 08:49 PM   #10
hovis
Some degresser can make the ally frame go streaky
Paraffin cleaning question skyline SV Talk, Tuning & Tweaking 20 14-10-08 04:15 PM
Dumb cleaning question skyline Bikes - Talk & Issues 10 28-07-08 02:46 PM
Cleaning question ... Pedro68 Bikes - Talk & Issues 12 25-09-07 07:18 PM
Rear Brake Cleaning Question glade SV Talk, Tuning & Tweaking 3 11-07-07 05:53 PM
Want to sell my bike!!! sluff For Sale - SV's and SV related items 0 21-05-07 10:42 PM
