Old 04-09-07, 06:47 AM   #1
enduroman
Default 2 left indicators + clutch lever + gear lever for pointy k6
Anyone help?
Old 04-09-07, 08:12 AM   #2
SoulKiss
SoulKiss's Avatar
Default Re: 2 left indicators + clutch lever + gear lever for pointy k6
Originally Posted by enduroman View Post
Anyone help?
Drop it on the left did we?
Well been there, doen that, as have many people.
Which is why you are unlikely to get those items.
I know that I am personally hoarding my indies from when I swapped to LED ones "just in case" same would be for any of the levers.
Expensive part of the repair is the gear lever - how bad is it?
If its just the rubber bit thats gone you can do a suitable drill and bolt repair to it, just search on the forum, I beleieve there are even pictures
David
Old 05-09-07, 08:39 PM   #3
M65
I think I have a clutch lever at home somewhere
Old 06-09-07, 09:26 PM   #4
enduroman
thanks for replies people. much appreciated.
items no longer needed now.
bit the bullet and bought new items above plus bar end assy and gearlinkage rod....£157 quid from fowlers of bristol....everything in stock though which was good.
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
need clutch lever and a gear lever! matt90 Stuff Wanted 0 23-11-07 02:08 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch Bayside GTR Stuff Wanted 5 23-11-07 11:54 AM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
