Old 04-09-07, 03:28 PM   #1
neraz
Default my bike won't start
I am having a problem with my bike. It just wont start.
I charged the battery to full. everything works, the lights everything. but when i try to start my bike a "dhut" sound comes and everything dies. i just can't figure out what the problem is. if anyone could explain it to me I would be very thankful.
Thank you
Old 04-09-07, 03:43 PM   #2
hovis
Default Re: my bike won't start
what bike is it?
please explain "dhut" a bit better,
Old 04-09-07, 04:07 PM   #3
neraz
its 2003 sv 650s
the "dhut" sounds like a knock. it comes somewhere around from the battery
Old 04-09-07, 04:09 PM   #4
Alpinestarhero
Got a multimeter and a haynes manual? Then you can test the circuit for any problems?
I'm not electrically minded, so I can't offer any better advice than this A haynes manaul will guitde you through everything and tell you what everything should be though
Matt
Old 04-09-07, 04:25 PM   #5
Raf
What model is it? Is it alarmed?
Old 04-09-07, 04:28 PM   #6
Alpinestarhero
Ah! he's got a point. Alarmed and imobilised? They always throw up problems. Chuck it out and get an alarmed disc lock, if you have an alarm / imobiliser combo thingy
Matt
Old 04-09-07, 04:35 PM   #7
Biker Biggles
Biker Biggles's Avatar
Loose battery terminals?The phutt noise could be the wires coming adrift from the terminal when you apply current to start it up.
Old 04-09-07, 04:49 PM   #8
neraz
its not alarmed. the bike fell off when it was parked and the clutch lever broke so i replaced it. now the bike won't start. I tried surfing the site and found out something about clutch sensor. but don't know where its located. if anyone can point out i'll check on that too.
Old 04-09-07, 04:52 PM   #9
Alpinestarhero
The clutch cut-out switch is located near the pivot point of the clutch lever itself, I think?
Matt
Old 06-09-07, 03:08 PM   #10
neraz
well the clutch lever sensor is fine.
My Bike Won't Start :( arcdef SV Talk, Tuning & Tweaking 34 01-02-09 08:38 PM
Help! bike doesn't start DJ828 Bikes - Talk & Issues 10 26-03-08 11:12 PM
bike won't start magicrat SV Talk, Tuning & Tweaking 9 16-02-08 02:31 PM
My Bike Won't Start! Yellow Bikes - Talk & Issues 4 01-09-07 08:31 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
