Old 04-09-07, 04:30 PM   #1
chipnix
Default TL1000 Idle speed adjustment....??
Hi all,
Done a search on the internet and cant find a thing - i know on the sv its just a cable that you can adjust, but where is it on the TL?
Old 04-09-07, 04:33 PM   #2
Alpinestarhero
Default Re: TL1000 Idle speed adjustment....??
There's probably a similar adjustment hidden away on some side of the bike
Does it say in the handbook for the bike?
Matt
Old 04-09-07, 04:52 PM   #3
There isn't one mate, your engines knackered, you should sell it to me...
Old 04-09-07, 05:33 PM   #4
Spanner Man
Good evening.
On the TL1000s the adjuster is on the left between the cylinders. ON the TL1000r it's mounted higher up & you may have to lift the tank to access it. On either model it's a similar knob type as found on Curvy 650's.
Cheers.
Spanner Man
Old 04-09-07, 05:36 PM   #5
TSM
The Sick Man
TSM's Avatar
Originally Posted by Spanner Man View Post
Good evening.
Cheers.
On the TLS, its mounted on the left, on one of the engine mounting pinch bolts, usualy. On the TLR its fiddly, it popped bettween the frame and tank, but both accessable without lifting the tank unless someone has relocated it.
Idle speed? weecorey SV Talk, Tuning & Tweaking 4 07-02-09 09:30 PM
Engine Idle Speed ozborn SV Talk, Tuning & Tweaking 27 16-12-08 04:08 PM
idle speed ? svdaz SV Talk, Tuning & Tweaking 11 29-04-08 05:32 PM
HOW to change idle speed andygib SV Talk, Tuning & Tweaking 4 31-01-07 04:09 PM
Idle Speed stevelondon1979 SV Talk, Tuning & Tweaking 8 23-03-05 09:10 PM
