Old 16-09-07, 09:58 PM   #1
John 675
Default steering question
when im riding along my bars are quite alot more to the right than central. the only thing i can put it down to is lowering my tyre pressures.... could this cause the problem? the are currently set to track pressures..??
Old 16-09-07, 10:02 PM   #2
hovis
Default Re: steering question
eh?
how can tyre prssure affect the bars? you do mean handle bars?
slacken off the clamps that hold the bars in place and adjust acordenly
Old 16-09-07, 10:15 PM   #3
leemole
u sure it isnt just the camber of the road ?
Old 16-09-07, 10:19 PM   #4
Jase22
Bent bars?
Old 16-09-07, 10:38 PM   #5
seedy100
Mine are like that as a result of an off about two years ago.
I have tried loosening off the clamps etc but as soon as they are tightened up again the twist comes bac; it seems to be the bottom clamp thats bent.
The bike has been MOT'd twice since, thefirst time I even pointed it out to the tester, who said that as long as the wheels were in line it was no problem!
TBH I am used to it and reckon I will have a bit of a problem when I change the bike for one thats not crooked
Old 17-09-07, 07:25 AM   #6
Spanner Man
Morning all.
Either you have a bent fork leg or bent handlebars, or your forks are twisted in the yokes. If they're bent you have a problem, but to untwist them loosen the steering stem nut slightly, & fully loosen the lower yoke pinch bolts. Then by placing the opposite to the direction the bars are going front edge of the tyre against a wall or some suitable immovable object, you should be able to realign the forks by applying pressure to the handlebars. Sometimes you have to give the tyre a gentle tap against the wall to get it all to move. You might have a bit of trial & error to get it right, as it's easy to go too far the other way.
Mind your wheel rim & discs etc if you try it, & don't forget to do everything up before going on the road.
Cheers.
Spanner Man
Old 17-09-07, 09:31 AM   #7
John 675
Exclamation Re: steering question
well mine was from an off i had about a year ago, but i replaced everything except the actual fork legs minus stashions, Kwak sold me his old yokes and they were spot on, had it all fitted and the steering was perfect, then i had my tyres changed and it was bent?.... dont know how though.... ill try tinkering with the nuts
Old 17-09-07, 11:20 AM   #8
Berlin
Originally Posted by Spanner Man View Post
Morning all.
Cheers.
+1
steering damper. TOY40 SV Talk, Tuning & Tweaking 5 24-06-08 12:32 PM
steering damper. scottjames SV Talk, Tuning & Tweaking 13 07-03-08 01:59 PM
Backwards steering wtdafk Bikes - Talk & Issues 4 16-02-08 01:16 PM
Steering lock for Steering damper Sideshow#36 SV Talk, Tuning & Tweaking 8 30-08-07 11:18 PM
Steering Stem Assembly Question Torn-Thorax SV Talk, Tuning & Tweaking 1 21-04-07 08:05 AM
