Exhausts Post your own reviews, opinions and experiences on this subject.
Old 18-09-07, 04:44 PM   #1
Berlin
Default Baffled (with a CCC)
How does one remove ones Baffle from a CCC oval Stainless can?
I've drilled out the Rivet. Now what?
I've tried padded pliers. No joy
I've tried heating it up. No joy
How do you get it out without marking the exhaust? It's stuck fast.
Cheers,
Carl
Old 18-09-07, 05:33 PM   #2
pmapp
pmapp's Avatar
Default Re: Baffled (with a CCC)
It is a bloomin tight fit.
I worked mine out very slowly with a screwdriver - to get it moving.
Old 18-09-07, 05:47 PM   #3
fizzwheel
fizzwheel's Avatar
I've heard a few others use the trick of shoving a broom handle up the exhaust with a sharp tap on the handle on the ground you might find that it frees the baffle.
You'll want to put the brom handle in from the front, the end where the link pipe fits to the orginal system.
Old 19-09-07, 08:21 AM   #4
Jdubya
You could also try wd40 between the baffle and the exhaust outlet then grip and pull on the inner "round metal bit" using a set of pliers...thats how I got mine out of my CCC oval stainless.
Old 19-09-07, 04:38 PM   #5
Captain Nemo
i got hold of the baffle with pliers and started to give it a violent twist,
amazing how hard they are to get out, yet if i try to put them back in theyll just fall out..............
Baffled drefraser SV Talk, Tuning & Tweaking 12 08-01-08 12:51 PM
baffled kwak zzr Idle Banter 13 03-11-07 06:53 PM
baffled gettin2dizzy SV Talk, Tuning & Tweaking 19 09-08-07 07:54 AM
Baffled tomjones2 Bikes - Talk & Issues 2 03-06-07 06:37 PM
Baffled!!! siementool Exhausts 2 17-07-06 09:50 PM
