Old 19-09-07, 07:17 PM   #1
Warren
Default photography - polarizer filter
circular polarizer filters . . . talk to me.
got a few questions.
i know they add more contrast to your photo's,
but whats the difference between a linear and a circular one ?
im after a 52mm screw filter for the nikon D40, can anyone recommend any brands or anything ?
i dont really trust jessops advice, as they generally try to sell you their most expensive product.
Old 19-09-07, 07:19 PM   #2
Default Re: photography - polarizer filter
You sounded like terry tibbs there
Old 19-09-07, 07:59 PM   #3
southy1978
http://www.luminous-landscape.com/tu...larizers.shtml
Should have all you need to know
Old 19-09-07, 08:23 PM   #4
Mr Toad
Linear and Circular Polarizing filters both have the same effect, but most metering and focussing systems on SLR's (inc Digial SLRs) won't work properly with a linear one, so you'll need to buy a circular one. Make sure that you can adjust it (ie. turn it round) so that you can see the effect, be it to make the sky darker, or remove reflections. You don't want one that just screws into the front element of the camera as it will be almost useless. I use one from Cokin, from their professional range - because they're bigger than the amateur range, and if you start trying to use a wide angle lens, you'll need a big one
hth
Old 19-09-07, 08:34 PM   #5
Warren
ok cool, would you recommend a hoya branded circular polarizer filter by any chance ?
why not a screw in one out of interest toady ?
i dont want to be spending thousands, but then i dont want one that does pretty much nothing .
Old 19-09-07, 10:54 PM   #6
rob13
Ive got a hoya digital one. Works a treat on mine
Old 20-09-07, 09:53 AM   #7
fubber
[quote=Warren;1291887]
[snip]
why not a screw in one out of interest ?
quote]
The filter does not affect all areas of the image the same - As Toady says you need to be able to rotate a polarising filter to gain the effect you want - so you should always buy one that 'floats' freely when mounted to the lens - essentially you need to compose your shot then rotate the filter to get the effect (deeper sky for instance) than you would get without the filter - as you rotate the filter you will see your composition change subtly - when you like what you see then then take the shot.
Note - you do get ones that 'screw in' but also 'float' once attached to the lens. That luminous landscape link above probably explains all this better...
Old 20-09-07, 12:59 PM   #8
stewie
Polarisers are one of the best filters to use on a camera, they cut down refelection by altering light paths, so you can cut down sparkle on water for example, they will also lose you f stops of light so a shot which would be say 1/500 secs at f8 with out a ploariser may be 1/125 at f8 with one so you may need to use a tripod, get em right and the effect can be brill, get it wrong and it will look like everyone else who usd to use Velvia to photograpgh a lone tree in a field of oilseed, if you know what I mean
AR Photography Gordon B 2008 Annual Rideout 12 30-06-08 08:42 AM
RawAction Photography El Saxo Track Days 1 08-04-08 09:57 AM
Photography Kit southy1978 Idle Banter 0 19-02-08 11:19 PM
Cameras and Photography rob13 Idle Banter 37 23-08-06 07:43 AM
Photography localhost Idle Banter 16 22-01-06 07:59 PM
