Old 20-09-07, 05:49 PM   #1
Fraser24
Default Oil Grade
Just a bit of info for anyone interested. I changed my engine oil to 15/50 w fully syn as my curvey has done 30k miles and I was shortly going to the South of France where it can be Very warm . After a couple of days my clutch started to muck about. I stripped it and found very little oil on the plates. After investigating the workshop manual I spotted a reference to "oil jets" in the lubrication system. I guessed that not enough oil was getting to where it needed to be due to the thicker oil, so I changed back to 10/40 semi-syn and the clutch is now perfect
Old 20-09-07, 06:36 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Oil Grade
yep, fully synth is a waste on an SV, what the manuf recomends is usualy more than good
Old 21-09-07, 07:26 AM   #3
Spanner Man
Good morning.
The Nips have always recommended 10/40, as indeed a thicker oil will not flow fast enough down the narrow oil ways found in modern engines.
Kawasaki caused confusion, as they used to recommend 10/40, 15/40, or 20/50, in their handbooks. But their main recommendation was for 10/40.
Semi synthetic is fine, but at the risk of starting the 'great handbag flinging oil debate' of 2007 again, I always advise my customers to use fully synthetic.
Cheers.
Spanner Man
Old 21-09-07, 07:32 AM   #4
Viney
Cheers.
Why?
Old 21-09-07, 08:02 AM   #5
Spanner Man
Morning all.
This subject has been covered many times before, & usually starts a right good handbag flinging contest.
Suffice to say, that in my 30+ years of fiddling with engines of all kinds, I have found that providing it's of the correct grade & type, the better an oil is the longer the engine will last, be it in a bike, a car, a boat, a generator, or a triple expansion steam engine for that matter.
There are many differing opinions on the subject, cost being one, but I speak as I find.
Cheers.
Spanner Man
Old 21-09-07, 10:33 AM   #6
embee
embee's Avatar
This is a very broad brush statement, and I don't intend to provoke a lot of response, but the general guide I'd recommend is to use as low a viscosity as you can get away with.
See what the ranges are that the manufacturer recommends in the handbook, and stick to the lower end unless you have really good reason not to.
Half the job of oil is to cool, and as said in earlier posts, modern engines are designed to flow substantial volumes of oil around the place to this end. Big ends in particular need good flows, the oil film thickness and load bearing capacity is generated by the rotation not the supply pressure, as long as it has plenty of oil supplied to it.
Plain bearings are designed to run satisfactorily on the lower end of the viscosity range, and high pressure contact regions like cams/followers and gear teeth take the oil into highly non-Newtonian behaviour as the apparent viscosity changes with extremely high pressure (thin films and high shear rates) found in these contacts, (potentially 100,000psi=600N/mm2 contact stress) and it's the additives (ZDDP etc) which do the scuffing protection here (cheapo oils tend to cut back on the additives).
Synthetics have an advantage in the high local surface temperature areas like top rings etc, but most engines are designed to cope with semi-synth oil characteristics and limits anyway. Service interval is the other factor.
Personally I use good quality semi-synth in my bikes and fully synth (Mobil1 bought in French supermarkets at half the cost here in the UK) in the car with a considerably longer service interval (10k miles/12 months).
As an aside, hydraulic lash adjusters/tappets tend to work much better with lower viscosity oils, the filling is better so they are stiffer in use. If your engine has them then definitely don't use higher viscosity oil than recommended.
Old 21-09-07, 02:35 PM   #7
SV650Racer
I only ever use or recommend 10W/40 Semi synth for the SV650. Like Silkolene Comp4 which is a higher grade Semi. Super4 though is more than adequate.
We only ever use this in our race engines, same with our powerbike engines even when tuned.
Being sponsored by Silkolene and having long chats with the guy from Silkolene he also advised the same - semi synth 10w/40.
front end up grade Taylor1975 SV Talk, Tuning & Tweaking 10 25-03-08 07:18 PM
WHAT GRADE FORK OIL ??? Stormspiel SV Talk, Tuning & Tweaking 2 19-07-05 06:29 PM
