Old 14-10-07, 02:58 PM   #1
natcar
Default Racetech emulators
I have inherited a set of racetech emulators and springs from previous owner. The front shocks are noticeably clunky/noisy and spongy. I have calculated that I need 0.85 kg springs from racetech website (my weight is 87kg) but the ones I have are 1.0kg which is a bit too stiff? I presume it will be an improvement over stock anyway so I should just get on and fit them or would it be uncomfortable/unsafe. Would I be better off bunging them on ebay or selling to somebody on here with a bigger beer gut than me?
Old 14-10-07, 05:41 PM   #2
Default Re: Racetech emulators
I'd not fit those springs if I was you, if a job's worth doing it's worth doing right IMO... And you should be able to sell them easily enough. You'd probably be happier taking a loop off the stock springs than using those ones, they really are pretty hard for you.
Old 14-10-07, 05:44 PM   #3
Lissa
Just Ballast
Lissa's Avatar
Agree with Northy. We have 0.95 springs but we are two-up all the time with a combined weight a lot more than yours
Old 14-10-07, 05:58 PM   #4
Where do you do that on their website?
Old 14-10-07, 06:25 PM   #5
chazzyb
I calculated I needed .85kg springs also (fat sod, me). PDQ however recommended that I go with .80kg and use 15W oil rather than 20W. I fitted it all *yesterday* (springs and emulators). First impressions didn't give that me that "WOW, what a difference" I'd been hoping for. However, I've been out today with my IAM group and I reckon the high-speed behaviour is much better. Now then, what's the shock of choice...
Old 14-10-07, 07:17 PM   #6
natcar
http://www.racetech.com/evalving/menu/searchstreet.asp
Link for the calculator above. I'll probably sell them on then, so unless I put on a lot of weight in next few days they will be available to anybody who is interested?
Old 14-10-07, 07:43 PM   #7
http://www.racetech.com/evalving/Spr...pringType=Fork
This is what it said:
Rider Weight: 147.5 lbs.
Recommended Spring Rate: n/a kg/mm (use closest available)
Stock Fork Spring Rate (measured): kg/mm (stock)
No Spring Series available for your bike.
Please call technical support (951)279-6655 for help.
Old 14-10-07, 07:50 PM   #8
21QUEST
21QUEST's Avatar
Here you go
Use this link http://www.racetech.com/evalving/menu/searchstreet.asp
Ben
Nemo me impune lacessit.
Old 14-10-07, 07:55 PM   #9
Blue_SV650S
I'd go with 80s too ... the 100s will be silly ...
Old 14-10-07, 07:59 PM   #10
natcar
Can I just fit the damping cartridges and use original springs? Would this get rid of the clunking/ improve anything? If so is 20w oil correct?
Racetech Emulators for 99 - 02 curvy (brand new) charlie13 For Sale - SV's and SV related items 15 13-03-09 05:50 PM
Racetech emulators - what fork oil? skov SV Talk, Tuning & Tweaking 0 27-05-08 10:36 AM
racetech emulators weazelz SV Talk, Tuning & Tweaking 23 02-10-06 10:43 AM
Racetech emulators ajbuchardt SV Talk, Tuning & Tweaking 1 12-08-05 05:32 PM
Racetech Emulators and springs pjsv650s Ancillaries 3 30-07-05 12:58 AM
