Old 16-10-07, 05:27 PM   #1
Default I can make the idle speed lower than normal using the throttle
I just noticed this today when I was moving the bike back out of a space. Dont know if it is normal or not?
When I forcefully turn the throttle in the close direction the normal idle speed decrease by a few hundred rpm.
Old 16-10-07, 08:01 PM   #2
Default Re: I can make the idle speed lower than normal using the throttle
Stuck or badly adjusted cable methinks
Old 16-10-07, 09:22 PM   #3
toonyank
Yup, sounds like it's not returning fully closed.
Old 17-10-07, 06:38 AM   #4
Spanner Man
Morning all.
Providing that the engine is idling at the correct speed, & that you have the correct amount of play on the cables, it's nothing to worry about.
Any machine with twin cables will do this, although it's not a good idea as it will eventually distort the throttle linkage.
Cheers.
Spanner Man
Old 17-10-07, 08:38 AM   #5
chazzyb
The original Honda CB750 did this by design; possibly others too.
Idle speed? weecorey SV Talk, Tuning & Tweaking 4 07-02-09 09:30 PM
idle speed ? svdaz SV Talk, Tuning & Tweaking 11 29-04-08 05:32 PM
2001 SV Idle Speed Jamie_SV SV Talk, Tuning & Tweaking 12 23-02-08 06:02 PM
HOW to change idle speed andygib SV Talk, Tuning & Tweaking 4 31-01-07 04:09 PM
Idle Speed stevelondon1979 SV Talk, Tuning & Tweaking 8 23-03-05 09:10 PM
