| SV Talk, Tuning & Tweaking Discussion and chat on all topics and technical stuff related to the SV650 and SV1000 Need Help: Try Searching before posting |
Junior Member
Hi
does anybody have any tips on how to remove the front wheel, I need to replace the speedo sensor, can it be done with a trolley jack? Is there anyway of using a rear paddock to do this job? Thank you |
Cazza's Bitch
You can do it by supporting the rear with a paddock stand then jacking under the engine to raise the front wheel off the ground. There's a thick flat spot on the bottom of the engine that works well for this.
(I'm assuming you have a pointy from your name!)
...or I'll f*** ya! |
... and if you don't have a rear paddock stand you can jack it up in the same place using the side stand and rear tyre.
However this is very close to the balance point of the bike until you have the wheel out so you may need to hang some heavy stuff off the grab rail to help keep things stead. Bucket of sand, water or a bag of soil will do it. |
Hi,I have used a jack placed just behind the oil filter (on the flat part of the underside of the engine) but find that if you lift it too high the bike is VERY unstable. So........I now physically life the front wheel while a mate places an axle stand under each of the forks - whi makes the bike very stable.
Yellow SK1 - Carbon Hugger - fender extender, OEM lowers and tasefully applied decals at the moment - no tarts handbag for me ! |
Junior Member
cheers lads for all the info, i do have a rear paddock, i think i will go for that method along with a trolley jack as Bear posted.
Pointy |
Cazza's Bitch
By the way: welcome to the Org!
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front Paddock Stand | Steve_God | Stuff Wanted | 2 | 23-10-08 03:57 PM |
| Front Paddock Stand - which one? | Tim in Belgium | Bikes - Talk & Issues | 23 | 12-03-08 07:38 PM |
| Anyone want a front paddock stand? | northwind | SV Ecosse | 13 | 24-02-08 09:31 PM |
| front paddock stand | kwak zzr | For Sale - SV's and SV related items | 4 | 18-01-07 03:33 PM |
| Front Paddock Stand | Banus | Bikes - Talk & Issues | 7 | 10-07-06 10:46 PM |
