Old 31-10-07, 01:53 PM   #1
Viney
Default Recomend me an extrenal hard drive
Im after a 500gb external hard drive. My mate, who knows about these thing said a LaCie 500gb unit.
So opinions please.
Old 31-10-07, 01:54 PM   #2
Filipe M.
Default Re: Recomend me an extrenal hard drive
Might do. Western Digital do good ones for a good price too, check out the Essentials or MyBook series.
Old 31-10-07, 02:03 PM   #3
Sudoxe
As above, mybook or lacie, both good products (i've only used a mybook though)
Dan
Old 31-10-07, 02:10 PM   #4
Grinch
Looking on hotukdeals.com
LaCie 500GB £53.98
Old 31-10-07, 02:11 PM   #5
ooger
We got a 500gb Lacie Ethernet Disk Mini which is networked as well as with USB connection. Its handy if you for example want to access your legit movie downloads on your telly while your PC is off.
Very good http/web user interface too.
(If you're looking to mirror them or expand at a later date though be careful, we also got another 500gb Lacie USB disk and will it heck recognise its plugged in to the ethernet one making it ~1Gb.)
Personally I'd recommend an ICY BOX external caddy, and a standard big-as-you-can-buy fast (7200rpm) IDE disk. Much cheaper, and just as reliable, just USB though.
HTH
Old 31-10-07, 02:15 PM   #6
timwilky
timwilky's Avatar
for my laptop I bought a SATA card and then a SATA/USB external enclosure and a 500GB Seagate drive.
I wanted SATA all the way as a damm sight faster than a usb bottleneck
Not Grumpy, opinionated.
Old 31-10-07, 04:10 PM   #7
Viney
Mines only going tobe for extrnal sotrage of 500gb's of music, so not really het up on speed. I have used a mteas Maxtor item, and that worked a treat for listening to the tunes.
Grinch, thats a cracking deal, even better with the £10 off is you use google checkout. Job done. However, it isnt the Porsche desgin one, but i'll let you off.
Cheers mate.
Old 06-11-07, 11:23 PM   #8
Viney
So then, got my LaCie 500gb drive.
Its formated FAT32 and at 465gb. Why? Shouldint it be neaer 500gb and NTFS?
Helps
Old 07-11-07, 07:59 AM   #9
gettin2dizzy
It depends on what size files you are storing, as for the capacity that's just a bitch. It means 5000 000 bytes, which equated to 465Gb. A marketing trick used by every firm.
Old 07-11-07, 08:54 AM   #10
Viney
Music only
New Hard Drive - Noise? 600+ Idle Banter 3 30-03-09 06:17 PM
hard drive problems sv_rory Idle Banter 25 21-12-08 03:32 PM
How hard is it to drive a train? tigersaw Idle Banter 38 22-03-08 11:55 AM
IT help - hard drive question will Idle Banter 7 25-05-06 06:42 PM
pc hard drive question will Idle Banter 6 15-05-06 02:38 PM
