Old 03-11-07, 11:53 AM   #1
NedSVS
Default Carb Heater Part Number????
Can anyone provide me with the correct part number for curvey cab heaters as my dealer is struggling to get them for me. I know there is a lot of scepatcism about whether or not they do anything, but thought I might try a new pair of heaters with plenty of thermal paste. I will also be extending the wires of the temperature controlled switch so it is right at the front of the bike in one of the small holes in the front of the fairing, to make sure it is absoluteley as cool as possible. Thanks.
Old 04-11-07, 06:49 PM   #2
petevtwin650
Default Re: Carb Heater Part Number????
Searched hi and low. Can't find them myself. The Haynes manual says Uk models only ( so it must be true), but even so a UK dealer should have the relevant fiches I'd have thought.
Old 05-11-07, 11:04 PM   #3
I need to replace one of mine- the rubber seems to perish and they fall in half. I replaced both of the original ones with the ones off my spare carbs, now one of those has dropped off too
Old 06-11-07, 08:22 PM   #4
efi
whatyears are your bikes as i have access to suzuki parts fiches
Old 06-11-07, 08:24 PM   #5
efi
Are we talking carb heaters here & if so what year & model are your bikes
Old 06-11-07, 08:29 PM   #6
NedSVS
2001 SV650S if it helps. But I think you will find all UK sv650's, 1999 to 2002 use the same carb heaters. As far as I am aware, carb heaters are UK only parts.
Old 06-11-07, 08:38 PM   #7
Lissa
Just Ballast
Lissa's Avatar
If it's through Alpha sports or any other American site they won't show the carb heaters, we've checked half a dozen of them. No carb heaters on American bikes it would seem.
Carb heater question sprocket SV Talk, Tuning & Tweaking 14 13-06-18 01:58 PM
Carb Heater Upgrade NedSVS SV Talk, Tuning & Tweaking 26 15-05-09 12:04 AM
Carb heater wire broken. hallasv SV Talk, Tuning & Tweaking 15 27-04-09 10:08 PM
Carb Heater Part Number shelleyamy SV Talk, Tuning & Tweaking 4 20-03-09 05:39 PM
Carb heater Jase22 Stuff Wanted 0 01-11-06 06:05 PM
