Old 03-11-07, 07:49 PM   #1
suzanne2869
Default ignition sv 650
bikes got a dicky ignition anyone got one in working order with key obviously cheap as poss collection or delivery thanks p.s 2000 curvy
Old 03-11-07, 09:38 PM   #2
Default Re: ignition sv 650
Whats up with it?
Old 03-11-07, 10:35 PM   #3
svrash
Pick up a pattern one new on ebay for about £35 IIRC, same as the SRAD one if that's any help
Old 04-11-07, 07:49 AM   #4
suzanne2869
thanks er key sometimes won't turn and doesn't operate steering lock either you have to do it a precise way but will have a look at the ones you mentioned too cheers
Old 04-11-07, 08:00 PM   #5
Biker Biggles
Biker Biggles's Avatar
Get some oil down the keyhole and anywhere else it will go around the lock barrell first.They can be tempermental but sometime some lube fixes it.
Old 04-11-07, 08:01 PM   #6
hovis
+1 for the oil
mate just got one from breakers £20
Old 04-11-07, 08:44 PM   #7
suzanne2869
will give it a go gotta look at thewiring too think its been trapped in the steeringlock at some point and speedo needle keeps bouncing about but i'm still really chuffed can't believe how quickly i've fallen in love
Old 04-11-07, 08:47 PM   #8
hovis
your not to bad either
Old 04-11-07, 09:52 PM   #9
Mines a little bit worn too, you have to push the key forward slightly on turning it, when you do that its fine.
The speedo bouncing is a sign theres a wire damaged, if not the speedo signal then the live to the clocks.
Old 05-11-07, 03:10 PM   #10
husky03
Item number: 270183719815
ebay-
What's up with the ignition? arcdef SV Talk, Tuning & Tweaking 14 17-12-08 11:15 AM
K5 SVS No ignition fizzwheel SV Talk, Tuning & Tweaking 26 21-12-07 02:42 AM
Ignition advancer? sixstring SV Talk, Tuning & Tweaking 19 22-07-06 06:39 PM
Help! Help! please, ignition problem cwachang SV Talk, Tuning & Tweaking 1 17-07-06 10:41 PM
IGNITION stewboy SV Talk, Tuning & Tweaking 14 15-01-06 01:08 PM
