-   Bikes - Talk & Issues (http://forums.sv650.org/forumdisplay.php?f=129)
-   -   steamy visor (http://forums.sv650.org/showthread.php?t=107102)
G 27-03-08 10:53 AM
Re: steamy visor
I wear glasses and its a real pain.
I use a pinlock although I'm really going off it.
I feel it blocks vision slightly, which when your wearing glasses as well is really annoying.
The pinlock also becomes dirty/scratched quite quickly as its soft, this is really noticable when you take it off to clean it, the difference is colour and vision with it off is significant.
wyrdness 27-03-08 11:19 AM
Re: steamy visor
Originally Posted by ranathari (Post 1457462)
Pinlocks can be fussy - mine fogs up at the bottom and forces me to dip my head to look at the clocks, which is annoying. Breath guards seem to do more than anything else for me.
I had the same problem with the pinlock. The solution is to adjust the eccentric pins to ensure a correct fit. It's a bit tricky to do, but mine's OK now.
Rhiwbina_Squirrel 27-03-08 06:24 PM
Re: steamy visor
Just pinched this from a RiDE mag regarding the washing-up liquid technique:
"A spot is all that is required, applied with the fingers, until the fingers start to grab at the visor. At that point polish with a soft cloth. Result? Clear vision for at least five days."
S'pose it costs nothing to give it a go.
andyharding 27-03-08 06:45 PM
Re: steamy visor
I find aftermarket dark visors work a treat as they are not 100% perfect fit so let a small amount of ait in.
I compliment mine with a fog city, and a foggy mask. it took a while to fit the foggy mask correctly so it worked but now i am 100% fog free.
Beenz 27-03-08 11:25 PM
Re: steamy visor
Another vote for pinlock here.
I tried the foggy mask but didn't get on with it, worth a try though.
thedonal 28-03-08 10:47 AM
Re: steamy visor
I use a visor spray- Holts visor spray- does anti fog and rain repellant at once (sprayed on both sides of visor, obviously...!).
This works well if you apply the spray in a different way to the can, which says spray on and wipe off excess & allow to dry. I spray on a generous amount, allow it to dry for a few mins and then polish with a cloth- this does a sterling job, even without a breath guard. I do 2 applications on particularly cold days and also use the breath guard (is an HJC FG-14 and has a removable guard), though I daresay a pinlock system is far better.
The spray goes on normally every 1-2 days, so is a lot of effort, but a can (about 5ish) lasts for a few months normally- more in summer, less in winter.
I have worn glasses under the lid and used above spray on them- but it's not so good with this. I wear contact lenses most of the time, so this is not a worry for me.
Have you considered contact lenses? Makes life a lot easier re bike lids (and other stuff). I personally don't like the idea of extra lenses/bits of metal and plastic knocking about in the lid if something bad happens.
Slight derail- has anyone ever tried PTFE spray (like Muc-Off bike protector) on the outside of the visor? I may try this with a spare old visor, when I order new ones soon- it does a cracking job of keeping rain and muck off (muc-off?!) the bike, but not sure how it'll obscure visibility. I've tried it on mirrors, but it looks like it needs to dry and a fair bit of polishing to keep the view clean.
Alpinestarhero 28-03-08 10:49 AM
Re: steamy visor
I got a breath gaurd. The only time my visor steams up is when i put on too many layers and get a bit hot and perspire at the lights
Matt
Steve W 28-03-08 11:19 AM
Re: steamy visor
Open face helmet + balaclava in winter... oh and only breathe at over 50mph, helps keep speeds up!
