Re: Fork spring replacement.
I have Hagon progressives & 15w oil in mine & love them. The difference is unbelievable over standard
What is required to do this , is it fairly easy for somebody like me (an engineer) to do ? . Is it just a case of dropping a leg out at a time , unscrewing the top , draining and dropping new oil and spring in ?
I like things a bit stiff;). I did try the ohlins for a week or two with 10w but my god it was like a bouncy castle. I can't be having all that movement up my shoulders, the suzy set up don't budge at all, it feels lovely and smooth, I get on well with it |
I fit a lot of Hyperpro progressive fork springs to SV's, more than any other product.
Hi, I have just fitted Hyperpro Springs to my SV pointy and I followed the recommended setting from Hyperpro, SAE 15w 140 air gap. I did find it still dived a little on braking and also it was a bit harsh over the bumps in the road, almost like it was skipping a little so I added another 20mm of oil which has helped a lot with the fork dive under braking.
The only thing I have found now is that it still a little harsh over bumps so I have reduced the pre load on the forks which has helped a bit. I was wondering if it would help more if I tried mixing 15w with 10w to give me 12.5w, would this work with the issue I am having. I am around 13.5 stone all kitted up. |
Yup a mechanical engineer :D , Dangerous Dave I`ve been looking at those hyperpro kits on Twinshack quite a few times , must admit they have caught my eye
I wouldn't recommend the full Hyperpro kit which comes with a replacement rear shock spring, its not the spring that is the problem with the OEM SV shock, its the actual shock itself! 'df1uk' - I have replied to your PM. |
Aaah I replaced the Shock with a GSXR1000 one at the weekend anyway , that`s why I want the front to suit now :D
