Re: Problem with handling of SV
I honestly dont think theres that much in it handling wise, My brother had an RVF that he'd lowered the front on to make it turn better. We had a play on a set of twisties we both knew, I couldnt leave him behind and neither could he leave me behind.
The SV seemed a bit quicker on intial launch, but the RVF gained a little as it picked up its revs, but not enough to get by me. 22K and no fork oil change, thats where I'd start, refresh the oil and it'll feel a whole lot better. Also at 22k your rear shock will be starting to go off if it hasnt already so you might want to have that looked at / replaced to. I refreshed the fork oil on my SV and fitted a new rear shock at 33K and it felt hell of a lot better to ride. |
A good RVF is a fair bit better than an SV IMO, but then it should be. But there's very few good ones left, most still have the original fork oil in. I've ridden 3 (I wanted to buy one), one was lovely, with gold valves in and a recent service, very nice. The other 2 handled worse than a stock SV.
If you're finding you have slow turn-in, lowering the front end or raising the rear will help that and it's cheap and fairly easy. The SV's not really that great in corners but it shouldn't feel heavy to turn, it should just be a bit iffy midturn. (and not like you describe either). I wonder... How much weight do you have on the bars? |
I was looking at other posts and deciding to get the forks serviced and change the springs as well. I will give a few garages a call. I have given my local garage a call, and they said it sounds like the rear tyre and I mentioned what you guys said. He has quoted £130 for fork oil (higher weight), metzeler z6 front tyre, and labour, disposal etc. Does that sound reasonable? |
It's not bad I'd say. Depends how much he's charging for the tyre of course! Servicing the front forks on an SV is very, very easy mind- take them out, turn them upside down ;)
There's not a lot that a front fork can do to slow turn-in, mind, other than be bent or be riding too high (ie too stiff, or too much preload) But the SV comes with very light oil anyway and now it's old, so it's still probably worth doing. |
I went down to my local dealer. The mechanic says it is definitely your front tyre that is causing the bad handling. Even though I have not reached the legal limit yet, the shape is pretty bad.
He has ordered a Met Z6 roadtec for tomorrow. I have been told it will be £78 inc fitting, disposal and balancing. Does that sound reasonable? Thanks Amrik Here are some pics I had taken earlier. http://i58.photobucket.com/albums/g2...s/IMG_0248.jpg http://i58.photobucket.com/albums/g2...s/IMG_0249.jpg http://i58.photobucket.com/albums/g2...s/IMG_0250.jpg http://i58.photobucket.com/albums/g2...s/IMG_0247.jpg http://i58.photobucket.com/albums/g2...s/IMG_0252.jpg |
Maybe you should opt for different tyres than you have fitted, it can make a lot of difference. I found that when I changed the tyres to Dunlop 207's I got an enormous amount of confidence for cornering etc. (bear in mind I have 2001 version of the sv..it could be a different tyre choice for a newer bike).
Jambo |
Thanks for the replies. The front is pretty bad!
the rear was changed at MOT time in April but the front has been on since 2004/2005. There must be nearly 10,000 miles on that front tyre. I have a Met Z6 on the rear so I believe that the front should be the same. The front tyre is triangular shaped! Anyways, if this does not make it handle well, I will get some hagon springs. |
