Re: Garage Electrics, Consumer Unit - Which One?
no you dont need to put the main supply to your garage off an rcd m8.
If your garage is seperate the house then you will need some mechanical protection for the cable supplying your garage either by using conduit or wiring it in steel wired armour cable. as for the pros and cons of ring main or radial is you can use more heavy loads like washers , dryers at the same time on ring mains where as in a radial heavy loads like this all the time would just blow the mcb. what do you intend to use in the sockets ? |
Personally I would advice you to ask your pet spark to look at your full domestic install and tell him what you want.
Issues that would concern me are that I would want my garage electrics to be fed through a RCD, I would want to know the routing of my house to garage cable, to ensure it is properly armoured and unlikely to be damaged etc. When I bought my 1960 build house 25 years ago, I condemned the wiring as soon as I tried to plug in my alarm clock in the bedroom and found the only upstairs socket was on the landing. No problem thought I I will extend the ring and then found the cable to be perished as soon as I lifted a floorboard. It is a pity that with the part P requirement it has stopped competent non registered installs as well as the cowboys. So pay your money and get it fully looked at. |
Worst case scenario would be the following items running at once:- hi-fi, fridge, battery optimiser for bike, a powered tool of some description and pond pump. |
What size of domino is protecting the garage supply?
Carlos: Garage is separate from the house, and from what I can see is a large grey cable heading from the main consumer unit under the floor - then emerging up outside of the garage in a armoured casing, then heading into the garage into the old "pasted it" consumer unit.
timwilky: we have a Part P certificate for the electrical installation for the house, and everything is fine and earthed well and was just advised to upgrade the main consumer unit, and garage consumer unit. Just cost for the main one is a little more pricer than to replace the garage unit, hence my working backwards from the garage first. |
You dont need to protect the sub main supplying the garage with an RCD as the unit that is going to be installed in the garage has rcd protection, PLUS your not supposed to have 2 RCD,s in stream. ( this is ok if you have a TN-S or TN-C-S system) if you are going to take the cables for the sockets and lights for the shed directly from the house CU then you dont need an rcd in the garage like you said. |
