Re: Beowulf end can Not legal ????
Re: Beowulf end can not legal?
Strange I see no mention of the OP asking if the can would pass an MOT etc.
His question (In the title) was "Beowolf end can not legal?". My reply is accurate. without BS/E stamps. The system fails to comply with the construction and use regulations and is thus illegal. Others have referred to the MOT. I simply pointed out that VOSA MOT requirements are not a test that requires adherence to the C&U regs. Therefore, you can ride out of a MOT workshop with a brand new certificate and immediately be hit with a fine of £30. I am no lawyer, but I think it is an offence under section 42 of the road traffic act to contravene the construction and use regulations. Our forum police friends will probably be more specific about the offence |
Anyway, OP passed the MOT - job done! End Chin |
"will my can pass an MOT" or "will I get a fine if pulled by pork" And it seems tim gave a full and clear answer. My answer is usually if it matters for the MOT, then you have a defective MOT tester. And if you're worried about £30 fine, crash damage costs more to sort than that! |
Believe me, the boys in blue who know their stuff and enforce C&U everyday will/do look for the correct stamps. and impose fixed penalty notices for their breach
Have a look at the motorcycle exhaust section of http://www.dft.gov.uk/pgr/roads/vehicles/vssafety/regulationsforpoweredtwoandt4564 Quote:
This relates to OEM exhaust:
"that with which the machine was first fitted" |
(i) that with which the machine was first fitted; or
(ii) clearly and indelibly marked with :- See? |
Thanks for all your feed back some interesting points mentioned, i've had a good look all over the can & there's NO lettering NO numbers NO evidence of any buffing/polishing out at all its completley naked.i'll just ride it and see if i cop for a fine etc or a warning.
