Re: Scottoiler. What do I need?
£65 here http://www.gear4bikes.com/acatalog/Scottoiler.html, think p&p was about 7.50 though!
See if george white do them, in last weeks MCN they had an offer, spend £25 or more and get a free goody bag of kit worth £75.
Scotty, well worth it 45,000 mls and counting on me viffer out of one gold O ring chain, don't for get to keep the chain clean. |
mines now in a bucket was a waste of time fitting it in my experince! took ages to get the flow wright kept throwing oil allover the back wheel then stoped working as the pipe from the t/bodies keep coming off!.. now i spend half an hour a week cleaning the chain and reaplying chain wax then whilst im down there i inspect the back wheel, chain tension, suppension and anthing else i can see as when i had the oiller i just used to leave it
I'm very impressed with my scottoiler - flow rate is easy to set up - nicely oiled chain - and I can honestly say no oil on my rear wheel!!
Ok, so I've got oil trickling down mt rear arm, where the chain guard is collecting a little - bit its all good!! |
+1 for Scottoilers, mine's kept my chain lubed up for the last 15,000 miles in all weathers.
Opinions of whether to use the standard injector or is the optional twin injector the much preffered option? about to fit a standard one to the new bike. :confused:
I believe the twin injector isn't required (and some have said it's worse than the single I think).
I use the standard injector and have never had any probs. |
Thanks for that, looks as though that's another £26 saved out of my pension. Plus what I guess is less heavy cleaning :thumbsup:
Mines been on since about 15k, had a new chain on at 18k. Currently on 41k on the same chain. Never bought any oil, I just use anything I have kicking about, chainsaw oil, old engine oil, cheap new engine oil, whatever. I did actually clean the chain once too. Undoubtedly you may look at my back wheel and say "a scottoiler throws crap everywhere", but I bet a spray-can lubed bike would be just as bad if you'd not cleaned it in 31k miles. |
