Re: A life saving skill.......
Altogether more appropriate.:D |
cheers Mark. |
I'm a qualified advanced first aider through work due to the conditions and environment we work in. The course was mind numbing as a lot of it is common sense but it is worth doing to reaffirm your confidence in any given situation.
If you are de-fib trained and see someone that needs help think where they may be close to your location. So in London, tube stations, shopping centres, maybe big buildings ect. Quicker a person gets help, better the chance they have. Most de-fib units such as this are automatic as well.
I was told on the training I did, most important get CPR started and don't stop until someone who is more qualified than you turns up. When it comes to it, do something rather nothing! |
99% of defibs available to the public are completely automatic. You attach the pads and press a button. The unit will then perform a test and decide whether to shock or not. Slightest bit of electrical impulse detected and it won't shock, including if someone is touching a victim. A 10 year old could use one.
The first hour is the 'golden hour' the better you do for the paitent in the 1st hour, the better the long term outcome. |
