-   -   Disabling parking light? (http://forums.sv650.org/showthread.php?t=164336)
phi-dan 24-03-11 10:09 PM
Re: Disable parking light
Originally Posted by beabert (Post 2508550)
Ok. Looking at the diagrams you cant cut any wires, they are used in the ignition ON' position too. That is my interpretation anyway.
Certainly looks that way.
Tracing all the wires from the switch, it looks like the Grey wire brings 12v to the Brown when the ignition is on and the light switch is on. Putting the ignition switch to P brings 12v straight to the Brown direct from the Red 'permanent' live.
As I see it, you should be able to disconnect the Grey and Brown from the switch and bridge them. This would allow the front side light and rear lights to come on when the light switch was on, but not with the ignition in P.
Obviously, you will need to satisfy yourself of this before trying it, and make sure all loose/cut ends of wire are properly insulated afterwards.
edit: this would only apply to curvies, pointy wiring is different iirc
When all is said and done, the best method is
Originally Posted by maviczap
Don't turn the key so far next time :razz:
especially as
Originally Posted by rictus01
it's an MOT failure and technically it could void anything but third party on your insurance
beabert 24-03-11 10:14 PM
Yep, Ill bodge something together tomorrow and report back lol.
hongman 24-03-11 10:38 PM
Let me know how you get on!
I can't be bothered to butcher my bike for this, especially being an ametuer at wiring I'm more likely to **** it up if I do it myself without guidance.
I really just wanted to know if there was a quick and easy way to sort it, otherwise I'll just leave it.
However if beab wants to volunteer info, I'm not going to complain ;)
rictus01 24-03-11 10:49 PM
you do of course realize it's an MOT failure and technically it could void anything but third party on your insurance :smt102
Cheers Mark.
phi-dan 25-03-11 09:04 AM
Re: Disabling parking light?
Hadn't realized that, so post edited.
I had done that mod on a previous bike, and then used the switched live in the P position to power a basic alarm. My mechanic / MOT tester at the time said it was a good idea, ah well
beabert 25-03-11 09:17 AM
I will never use the thing so insurance is a non issue here.
hongman 25-03-11 04:10 PM
My MOT guy didnt even check the parking light last time.
However, good point and worth bearing in mind!
beabert 25-03-11 06:58 PM
Ok done it, and tested.
As above, pull the grey and brown terminals from the green block and connect them together. To free the terminals Use a nail or something to pull the small green tabs inside back whilsts pulling at the terminals . All completely reversable, nothing cut.
http://i19.photobucket.com/albums/b1...CIMG0016-1.jpghttp://i19.photobucket.com/albums/b1...e/CIMG0014.jpg
hongman 25-03-11 07:42 PM
Well done mate, thanks!
I reckon I'll be doing that, looks simple enough even for me ;) come MOT time I can simply hook it back up if needed.
