-   Bikes - Talk & Issues (http://forums.sv650.org/forumdisplay.php?f=129)
-   -   Home anodising? (http://forums.sv650.org/showthread.php?t=171918)
yorkie_chris 20-10-11 02:05 PM
Re: Home anodising?
Originally Posted by Epic Monkey (Post 2617751)
Hmmm...this opens up a few options now. What do you use to make the colour?
Dye.
Do some googling :)
Jayneflakes 21-10-11 12:37 PM
Re: Home anodising?
What are the regulations on disposal of this kind of waste once the kit is finished with? I take it that if it contains hazardous chemicals, chucking it down the drain/toilet is out of the question and I am not sure that my local recycling centre are set up for it (they had enough trouble with an arm chair!).
Could be quite interesting as a home kit for small stuff, but anodised bits can look quite tacky, fairly quickly when the dye fades.
squirrel_hunter 21-10-11 01:00 PM
Re: Home anodising?
Originally Posted by punyXpress (Post 2617693)
Hasn't one of the comics just done an article on this?
Practical Sportsbikes did Zinc Plating the other month, similar process. Positive results.
Originally Posted by TamSV (Post 2617781)
I got a sulphuric acid burn on the n*ts many years ago that was enough to put me off messing with the stuff. :smt103
Pic's or it didn't happen.
TamSV 21-10-11 01:25 PM
Re: Home anodising?
You want to see pictures of my n*ts? Think very carefully before answering.
Specialone 21-10-11 01:28 PM
Re: Home anodising?
IMO it will never be as good as a pro job so just let them do it, same as chemical blacking and as Tam said, safer.
NTECUK 21-10-11 02:28 PM
Re: Home anodising?
But for loads of odd bits and bob's.Home be easyer.
1,Heel plates
2,water pump
3,prelaod caps
4fariring fixings
Its a few items when you add them individualy.
Owenski 21-10-11 03:43 PM
Re: Home anodising?
You'd be better off getting good at it and then setting a store up on here.
That'd make you money never mind saving you money.
Still... its not for me though :)
Bibio 21-10-11 03:45 PM
Re: Home anodising?
don't know if anyone has seen this but it's good info.
http://www.observationsblog.com/4/po...tery-acid.html
NTECUK 21-10-11 04:29 PM
Re: Home anodising?
Good man :smt098
Teejayexc 21-10-11 07:25 PM
Re: Home anodising?
...and I wondered why he called himself squirrel hunter...now I know :-?
