Re: Floppy clutch lever?
https://halnico.com/SV650/Clutch/SV650ClutchLifter.html My 99 gear changes are slick and problem free and almost like having an ,"Automatic" gearbox :D |
Well..... Brand new overpriced worm drive fitted everything adjusted and still not working. Exact same problems as first post :( :( :(
So what now, pull clutch plates out or? Gave up for today as chucking down and got soaked. |
Are the threads in the Clutch lever assembly end OK ?
Thanks for taking the time to read my confused ramblings. |
Was the clutch and cable OK before ? |
Yeah new cable and clutch plates and steels less than 400 miles ago and now new worm drive. I also get frustrated when i can't fix things but im doing everything ive always done and its not working grrrr. As i said in post 1 it all works for a few gear changes then stops and needs re-adjusting i'm losing my sense of humour quickly :p
https://www.reddit.com/r/sv650/comme...h_cable_loose/ I use blue thread-lock on the adjuster nut on the shifter/worm nut. They have some @ Halfords if you need some, https://www.halfords.com/motoring/pa...er-526632.html |
Thanks had a look still not whats happening. I have even tightened both ends of cable and marked them and the two bolts to check for loosening or movement and nothing not a single millimetre of movement....
Yeah, me too. Strange how it's just gone weird. Put away fine and working well and after a short rest it's gone daft, bike and me :smt082
