-   -   Ineffective blipping! (http://forums.sv650.org/showthread.php?t=57330)
jonboy 26-01-05 03:56 PM
Yes I agree with Scoobs, turn up your idle and see if it makes a difference. 1500rpm is a good starting point and then see if you can get away with a little less - different bikes will behave slightly differently largely because the carbs will have slightly different levels of tune/sync.
Barty_b0y 26-01-05 04:02 PM
Originally Posted by Scoobs
Bagazee, I was having similar probs recently and there was some advice on here about turning up the tickover. Mines at 1500 warm and I haven't had a jot of bother since.
fist day i rode my bike it was stalling coming up to jucntions and clutch in stuff had my tick over set to 1000-1100
this is too low its now set at 1300 and happy :D
BaggaZee 26-01-05 04:15 PM
IIRC mine's at about 1300 but I'll up it to 1500 for until it's a bit warmer.
I'll let you know how I get on..
Cheers folks!
Anonymous 26-01-05 05:18 PM
Someone should design a carb-heat system like there is on piston aircraft to redirect some of the engine heat to melt any ice.
I remember when I was doing my pilot training I suffered an EFATO (Engine Failure After Takeoff) in a PA-28 due to carb icing in the middle of summer. The dewpoint depression was about 10 degrees C at a temperature of approximately 18 degrees C - prime conditions for icing. Fortunately I landed back onto the same runway.
Now that I fly the bigger type of silver birds - all we have to worry about is bird strikes and terrorists. ;)
I suppose one other way of reducing carb icing would be to lean the mixture - as an over rich engine means the fuel acts more as a coolant which increases the chance of ice. From what I've read the carbed SV is slightly over rich - maybe this is for longevity and cooling reasons?
Baldyman 26-01-05 07:40 PM
-waves as he tootles off into the distance - on his 'orrible pointy" bike ...............with FI ;-)
Jabba 26-01-05 07:58 PM
Smug git :D
valleyboy 26-01-05 08:00 PM
Mwahahaha I have a pointy devils bike as well....
Sadly.. the only thing freezing up in this weather are my nads
John Burt 26-01-05 08:12 PM
cARB iCICNG
Dont all the carburrated bikes (SVs) have carb heaters, little brass nipple in the bottom of the float chamber from memory and a thermostat in ther LHS wiring loom??????
jonboy 26-01-05 08:47 PM
Yes but they don't seem to work too well.
mattyL 26-01-05 10:00 PM
My bike has been doing the exact same thing since it became really cold, I even had my throttle freeze open whilst going to work one freezing morning which was frigging nasty, so I tried some fuel additive to stop carb icing and that was problem fixed straight away. I use some stuff from halfords called " Dry Fuel" , comes in a purple bottle , costs about £5 and does two tankfuls.
