-   -   Quick turn throttle tube (http://forums.sv650.org/showthread.php?t=57538)
chris SVK3 07-02-05 06:30 PM
How much and where from for R1throttle tube. Also will it the K3 if so which yaer R1. Cheers Chris SVK3
Flamin_Squirrel 07-02-05 06:49 PM
See above - and yes it'll fit the K3.
Cloggsy 07-02-05 06:55 PM
Originally Posted by Flamin_Squirrel
New, kindly supplied by Mr Itchin2go 8)
Was £15 iirc and comes with the rubber grip too.
Does it come with instructions :?: :oops:
chazzyb 07-02-05 07:39 PM
Blimey, and I thought the SV had a quick-action throttle to begin with. I have an old British bike as well, with an Amal carb. Now that most definitely needs you to grab another handfull!
Flamin_Squirrel 07-02-05 08:07 PM
No, but its really easy, you'll manage - all the throttle slider is is a cylinder with the throttle cable wraped round it.
Take the bar end off. At the other end of the grip is where the throttle cable wraps round the slider - it's covered by an aluminium case in two parts, held together by two screws. Undo them, take the case off and unwrap the cables. The slider will now slide off the bar, replace with the new one.
chazzyb - how quick is a quick action throttle? :wink: As I understand it the SV comes with a 1/4 turn slider... replacing with the larger diameter R1 slider makes it 1/5 turn.
chris SVK3 07-02-05 08:09 PM
what year R1
BURNER 07-02-05 09:22 PM
Originally Posted by northwind
03/04 R6 is what you want for a carbed bike BTW. Not done it, yet.
You sure?
I'm off work t'morow so might swing past a breakers and see if they've got one.
By the way this is the link to Ronlarimers how-to but link doesn't work!!
http://www.ronlarimer.com/new/sv650/r6throttletube.html
Carsick 07-02-05 09:24 PM
Try this one http://www.ronlarimer.com/new/sv650/..._throttle.html
BURNER 07-02-05 09:27 PM
Cheers Mate,
I'll give a Yami dealer a call tomorrow and see if I can get a price. The 1/5 can insert is about £25- so if it's cheaper......
northwind 07-02-05 09:40 PM
http://www.svrider.com/phpbb/viewtop...er=asc&start=0
