I should be there as usual.
As will I, and I might even get to talk to some people that I don't seem to have got around to doing yet? :wink:
might wander through with Isaac.
Re waterproofs - I went to a camping shop and bought hiking jacket and overtrousers for a tener apiece. Fold up very small indeed so good for touring when you want to wear leathers all the time. Don't bother going to Hein Gericke as they're waaaay overpriced and don't make them small enough for us girls. If you go down the cordura road, I highly recommend Richa Monsoon kit, which has fine waterproofing and is great in all seasons as you can take the linings out. re back protectors - I've got a ladies knox stowaway too, which I got off eBay for next to nowt. But if you have to have Dainese try Sondel Sport on Holloway Rd (jusdt by Highbury Tube). They're a big Dainese stockist and will either have them or be able to order them in. |
be calling in on my way through tonight, not staying long will have the boy with me.
Cheers Mark. |
I shall be there from about 6:20ish I hope..
No, ill be at home makeing an "Engine mounting thrust adjuster socket wrench"
Dan |
Guess i'll be there again. If only to get wound up by Harley riders on the way there :oops:
Now now, no more of that behaviour from me for a whle i think ;) |
Newbie
I'd like to come along being new on the SV650 any one got a good route into London fron Tring/Watford. Also how long do peeps hang around for?
Re: Newbie
My autopilot course is usually go to hyde park corner. Follow the road towards picadilly circus, go into shaftesbury avenue (10-11 ish from picadilly circus), follow shaftesbury ave until you pass the wardour street lights and turn into the next left (Dean street). Follow Dean all the way to the top and turn right into soho square. Go round the square and take a left into frith street. We are parked outside Nero's at the corner with Old Compton St. PS. PM if you need more info. |
Re: Newbie
This is probably a bit late in the day but, in the absence of any other advice and assuming you don't know your way around in town at all, the easiest route I can give you is probably to follow the A41 then A1 all the way down to Highbury Corner, then down Upper St, then right on to Roseberry Ave, Theobalds Road, Holborn, Shaftesbury Ave and up Dean St and take the last exit off Soh Sq (by which time you'll be on the map) As I said, this is emergency advice. There's probably a much quicker way, but I don't usually approach from that direction. I;m sure others on here can assist in th elonger term. as for home time, its usually a case of last man standing :lol: |
