Interseting, ive had the same problem with me gszxr and have been scratching (me head (bidgnot little) befor the horn jokes start again) - I'm going to try spacing it awat from the rad.
I'll keep you posted. Jai |
Garry :wink: |
Garry, you've described it perfectly.
Our dealer isn't keen to swap the horn until it plays up for him, even though it's under warrenty. Nutty x |
OK, so what are the thoughts on what to replace it with? And do they require re-wiring, or is it a straight swap of the horn itself?
i used to ride an old 6v DR400 into london, horn was crap, until...............
i taped an air horn to the bars :lol: used to scare the crap outa people when they cut you up as they would think they`ed pulled out on an artic (lorry not roll! ) got through the MOT as well, mind u that was 20 years ago. try one, you`ll love it :) |
See, what I'm thinking is instead of a horn, strapping a small catapult (about the size that could be used to launch a rabid, half starved weasel) to the bars instead. I'm sure it could be initiated from the same button, not sure where I'd keep a spare supply of weasels tho...
Quite fancy one, may be good in an emergency and will **** a few people up when required! |
i fitted the twin fiamm horns to my sv you need to wire them in with a relay but it's really easy (i can do it so it must be)
you can buy a kit which contains 1 high tone horn 1 low tone and a relay for £15 from halfwits there are fittng instructions on the forum somewhere |
