Wheel alignment is the probably cause, that or over exhuberance(sp?) |
I'll check the alignment too though Cheers |
I wouldn't worry too much about the tyres. They are not the best tyres on the market but not totally ****e either.
At the moment I'm running a Mez4 front and Diablo strada Rear at the moment and it's far from lethal. The front is almost done to the edge and that's an original from a 99 bike :roll: :) . I did loose the front yesterday but not the fault of the tyres. I was taking the p**s a bit. Cheers Ben |
[quote="fullstop102"]Trick I was told from a friend that races is.. Pop the lube on at the end of a trip and then because you leave it a long time it will not fling off. Also makes more stick to the chain so you can get away with putting less on.[quote]
Yep, something everyone should know. Putting it on just after riding means the chain is warm so the lube is runnier and penetrates better. Leaving it for a while before riding means the solvent evaporates and the lube doesn't fling nearly so much. I found the stock tyres to be utter crap, but worse when cold not hot. |
LUBE!! I'v done this too :oops:
BTW: 020's are the bees knees, very trustworthy! |
Not quite as good in the rain either, but otherwise a very good tyre. Just a little behind hte curve now I think, it's an old design, still very good. I like the carcass shape too, I think it's slightly better than the Roadtecs. |
Quite likely lube as has been mentioned but also take a close looke over the tyres for signs of cracking in the rubber. This is a sign that the rubber is breaking down and time to get some new ones. If you park your bike up over winter it is also a good idea to have carpet or similar under the tyres so they are not on concrete as this is detrimental for the tyres too.
get em off and get Z6 ' on
