I have the grips wired up to a basic "load" switch now. It works but if I leave the switch on the grips just continue to heat up. There seems to be no limit. Which is why I wanted to put the oxford switch in to regulate the heat.
I shall have another go tonight. I was quite simply hoping that someone out there had the oxford switch already attached with the same colour codes and would be able to tell me which wire was connected to what on the bike. :roll: It seems it is not going to be that easy. Thanks for the input so far. |
